Brake lever clamp
CptBlack
PostPosted: 10:44 - 27 Apr 2010    Post subject: Brake lever clamp Reply with quote
Hi,
I managed to split the brake lever clamp. It's cast aluminium (apparently) and it just split when I was tightening it up. Rolling Eyes
I have a temporary fix in the shape of a strip of bent steel quickly fashioned by a mate.
Where can I get a replacement, hopefully without buying an entire reservoir and lever kit as the mirror is mounted on by the cylinder.
The bike is a hyosung cruise 2. The bar is 1 inch diameter and the distance between the bolt holes is about 1 & 7/16 inches as far as I can measure by eye (centre to centre)
Cheers,
Chris
Edit: I've tried breakers and online shops but no good Confused
jakeeNZ
PostPosted: 10:59 - 27 Apr 2010    Post subject: Reply with quote
This is the kind of thing that is not readily available so that you get stung for breaking it by having to buy a whole unit.
Find something similar second hand and use that.
And next time use a more even application of sensible fastener tension to do the job. Thats not the kind of thing that just happens, it is either a hard knock or you were doing it up excessively hard.
Yamaha - Best manufacturer of anything - anywhere
Paxovasa
PostPosted: 11:02 - 27 Apr 2010    Post subject: Reply with quote
Trty contacting this guy Thumbs Up
breaking a bike
CptBlack
PostPosted: 11:08 - 27 Apr 2010    Post subject: Reply with quote
Paxovasa: Many thanks for that. Email sent.
jakeeNZ: Granted, lesson learned. It was excessive tightening and I wasn't paying enough attention to the tension.
PostPosted: 11:38 - 27 Apr 2010    Post subject: Reply with quote
Very unusual to get a handlebar 1" in diameter (they do exist, but it's usually an oddity on stuff like Harleys).
Most standard motorcycle handlebars are 7/8".
CptBlack
PostPosted: 11:41 - 27 Apr 2010    Post subject: Reply with quote
Yeah, I found that problem when I replaced my switch gear - I had to file out the hole a bit more to make it fit
cb1rocket
PostPosted: 12:15 - 27 Apr 2010    Post subject: Reply with quote
most bike shop sell them as a mirror mount adapter, just works as well.
This is one I found, are you sure the handlebar is an Ø1"?
https://cgi.ebay.co.uk/YAMAHA-DT-125-DT-125-R-DTR-125-BRAKE-MAS-CYL-FR-CLAMP-/150429982804?cmd=ViewItem&pt=UK_Motorcycle_Parts&hash=item2306536054
these clamps are fitted as standard to alot of makes ie Honda, Suzuki Kawa.... etc
cb1rocket
PostPosted: 12:18 - 27 Apr 2010    Post subject: Reply with quote
https://cgi.ebay.co.uk/CNC-Billet-Brake-MC-Lever-Perch-Clamp-Mirror-Holder-/320485132280?cmd=ViewItem&pt=UK_Motorcycle_Parts&hash=item4a9e6707f8
another one etc, lots on ebay!
CptBlack
PostPosted: 12:25 - 27 Apr 2010    Post subject: Reply with quote
Cheers cb1rocket. What do you mean by Ø1"
The bar is 1" diameter. I've attached a pic with a tape by it to see the diameter needed.
cb1rocket
PostPosted: 12:35 - 27 Apr 2010    Post subject: Reply with quote
Ø1" means 1 inch diameter Wink
thats the symbol use for diameter. Ø25mm is 25mm diameter etc.
I have seen a few on ebay, might be worth asking the dealer whether they can get them in?
CptBlack
PostPosted: 12:37 - 27 Apr 2010    Post subject: Reply with quote
I never knew that, cheers cb1rocket.
Dealers phoned - he's checking the workshop.
Hopefully sorted soon
Cheers all!
The last post was made 15 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 65.66 Kb
