| kierontaylor |
 kierontaylor L Plate Warrior
 Posted: 22:48 - 27 Apr 2010 Post subject: Honda CG 125 High Beam Not Working!! |
Hi, I have owned the Honda CG 125 for a few months now and the high beam has never worked. It is an x reg (2000) model
When the lights are turned on the pilot light and the dipped beam works fine, but when i push the high beam button in, the lights all turn off and the bike is left in darkness
i have an MOT coming up soon and need to know what i can do to fix this and roughly how much it will cost  |
| nightshaddow |
 nightshaddow Nearly there...
 Posted: 13:28 - 28 Apr 2010 Post subject: |
daft question but have you changed the bulb? ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
Current rides CB 125 TDE(the next project) NS125RK ( now on the road ) CB125TDC (soon to be project 17) melody ( the nephews ) |
| Robby |
 Robby Dirty Old Man
| Alexio |
 Alexio World Chat Champion
| Paxovasa |
 Paxovasa World Chat Champion
| clancy |
 clancy World Chat Champion
| kierontaylor |
| cb1rocket |
 cb1rocket World Chat Champion
| kierontaylor |
| cb1rocket |
| kierontaylor |
| Walloper |
 Walloper Super Spammer
| kierontaylor |
| Walloper |
 Posted: 23:08 - 28 Apr 2010 Post subject: |
You need a voltmeter and a test lamp. Maplin are cheap as chips for this kind of gear. And you will have fun using this tool on all sorts of things.
Where do you start???
Take the bulb holder out.
Remove the bulb.
Key to ignition on.
Press the High Beam/Dip Beam switch.
See if the brake light goes off.
If so:
Put the volt meter on one of the contacts in the bulb holder.
If you get 12volts press the dip/hi beam switch this should take power off the contact your on and send it to the other contact.
Put the volt meter on the other contact to confirm.
If no 12 volts when you test then you have a short in that wire. Short means the electrical energy is passing through the bikes frame to earth.
The battery supplies 12v from the + positive post/terminal.
The 12volts travels through the circuits to whatever item you use : horn, brake light, indicators etc. and back to the - Negative post/terminal (Which is called the Earth.)
If the insulation around any of the wires TO an item is cut/rubbed through then when you activate that circuit the power will pass from the battery + to the switch then out to feed the unit ie hi-beam but since the wire is damaged the 12volts will take the path of least resistance and go back to the - negative post without passing through the hi-beam bulb.
This is called a 'Short Circuit' as the 12v is taking a short path from + to -.
To find the short:
There is no way to identify exactly where the short is but if you can expose all of the harness feeding the headlight you will be able to see if there is any fraying or pinching. Most likely this will be where the insulation is damaged.
It is not an easy task.
But it is possible to do this yourself so long as you do not rush. Try and be methodical. When removing things take photographs before you remove it. You WILL forget how they went when it comes to clashing it all back together again.
Or you can let a bike shop look at it for you and suck up the labour charges. ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| kierontaylor |
 Posted: 23:16 - 28 Apr 2010 Post subject: |
thankyou very much, i will have to take it round to my uncle , he should know what to do with your instructions as he is an electrician
if any1 has any other suggestions please do share as i really do not want to pay ridiculous labour charges  |
| Walloper |
| kierontaylor |
 Posted: 23:26 - 28 Apr 2010 Post subject: |
i'm only 19 haha, passed my full bike test at 17 as soon as i could, eligable to ride any bike now and i have 3 years no claims to  |
The last post was made 15 years, 244 days ago. Instead of replying here, would creating a new thread be more useful? |
