| moto |
 moto Nitrous Nuisance
| Paxovasa |
 Paxovasa World Chat Champion
 Posted: 18:23 - 29 Apr 2010 Post subject: |
To take the old chain off, just use a angle grinder  ____________________ Suzuki GSF600 K3 (in the fastest colour, black). |
| Walloper |
 Walloper Super Spammer
| stinkwheel |
 Posted: 18:45 - 29 Apr 2010 Post subject: |
I should point out that motorbike chains are not the same as bicycle chains. The ends of the pins are rivetted over. Once you remove a link, it is not a good idea to put them back in again like you can do with a bicycle chain.
They are normally supplied either endless, with a split link that is held on by a spring clip or with a rivet link (aka a "soft link") which you press on then deform the ends of using a special tool.
So.
If it has a split link. Take the split link off using a pair of pliers and a screwdriver to prise the spring clip off.
If it has a rivet link, you'll need either a chain splitter or to grind/cut the rivet link off.
To rejoin it afterwards, you would need either a new rivet link or a split link. Importantly, it would need to be for the same make of chain because they don't all use the same pin diameters.
A bicycle chain splitter is almost certainly not man enough for the job. Any bicycle ones that were would be so expensive that you wouldn't want to risk breaking them on a motorbike chain.
A proper motorbike chain tool will cost in the region of £65+.
I would strongly recommend against using a split link to join your chain except as a temporary measure to take it to a bike shop/mates house to have a rivet link fitted. That is however my personal oppinion, I hate the bloody things. Others use them and appear to have no problems.
There is also another way. Drop the swingarm and remove the chain in one piece. This may not necessarily be as much of a pain in the backside as it first appears. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| moto |
| stinkwheel |
| moto |
| Paxovasa |
| moto |
 Posted: 19:25 - 29 Apr 2010 Post subject: |
Yes the new link came with a little sachet of lubricant too.
I have just been to the garage and pulled the chain round a few times but could not find the connecting link, I looked on both sides of the chain, how odd!
So I will read up on how to take the swing arm off, but I still need to buy a chain splitter in order to fint the new connecting link?
On the chain box it says I need a DID KM500 cutting and rivetting tool to press fit the connecting link so I guess thos one is ok. £165 or £40 on ebay.
https://www.demon-tweeks.co.uk/Motorcycle/Chain_And_Sprockets/Chain_Tools/D.I.D_ZJ_Link_Riveting_Cutting_Tool/409/3509 |
| RichP |
 RichP Nova Slayer
 Posted: 20:22 - 29 Apr 2010 Post subject: |
Just cut through the bugger, back in the day when I couldn't afford decent tools I remember having to cut through the split link on an SR125 chain with a blunt junior hacksaw, no fun at all  |
| moto |
| stinkwheel |
 Posted: 23:13 - 29 Apr 2010 Post subject: |
It might have an endless chain on it which is why you can't find a rivet link.
That rivetting tool seems pretty cheap but looks quite robust and compact in design and it is the correct tool for the job you want.
It should split your current chain. You can split it on any link but as said, you'd need the correct brand of rivet link to re-join it again. I said to look for the rivet link because it makes sense to split it there if one is fitted.
If you're happy to be using DID chains, I'd go with that one. I suspect it will ONLY join DID chains though. If you're going to use other brands of chain, you might want a more universal tool.
The very best one is a whale.
I use a hein gericke own brand one that cost £65. Does the job fine. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| TUG |
 TUG World Chat Champion
| Walloper |
| TUG |
| yen_powell |
 yen_powell World Chat Champion
| moto |
| Kickstart |
 Kickstart The Oracle
 Posted: 09:19 - 30 Apr 2010 Post subject: |
The Ebay link to the splitting tool shows a styleI have tried before. Worked OK on 520 chains on 125s, but on a HD chain it just snapped rather than pushing the rivet through.
Some bikes taking the swinging arm out isn't that difficult. Also gives you the easy opportunity to greases the suspension linkages while is is apart.
There are 2 common kinds of rivet link (plus a 3rd kind which uses some kind of shear bolt to peen over the end). The soft type shown on yen_powells post which are not too difficult. The other type is just like a normal chain link, and most riveting tools will not do them. Quite likely it is this 2nd style that was used on the chain that is currently on the bike.
| Walloper |
 Posted: 10:22 - 30 Apr 2010 Post subject: |
Are you stealing coal from the local opencast using that bike?  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| moto |
| yen_powell |
| Walloper |
The last post was made 16 years, 67 days ago. Instead of replying here, would creating a new thread be more useful? |
