Wiring a different headlight to bike?
Misc
PostPosted: 21:41 - 02 May 2010    Post subject: Wiring a different headlight to bike? Reply with quote
Is the above hard? Looking for a new headlight but don't like any of the universal ones really. If i got a Kawasaki headlight for a Suzuki, would it be a lot fo trouble i.e soldering, relays, needing wiring diagrams etc? i'll give it a miss if it is. Smile
steven_191
PostPosted: 21:55 - 02 May 2010    Post subject: Reply with quote
not sure what most bikes use for headlight bulbs but its normally only going to be a 2 pin or 3 pin bulb. 2 pins are one filament and the 3 pins are 2 filaments. so all you would need to wire in is a ground, hi beam, and low beam. or just ground and low or ground and high, whatever the light is doing.
and you wont need to worry about increasing the cable size or using relays unles your adding lots more bulbs. even if you just add another 1 or 2 wouldnt be any different.
Ichy
PostPosted: 22:09 - 02 May 2010    Post subject: Reply with quote
Just check if the main bulb type is the same. If it is then there is no electrical work needed.
The worse that can happen is that you need to solder in a different bulb holder, three wires max.
Misc
PostPosted: 22:35 - 02 May 2010    Post subject: Reply with quote
Thank you both. Will try & get some more info on what type they are.
Misc
PostPosted: 11:42 - 03 May 2010    Post subject: Reply with quote
Bump!
I think i know what light i'm going for now, think it's universal & it looks like it's got 3 wires with bullet connectors.
Haven't took my standard light so would it just be a matter of cutting off my standard plug & then soldering new wires to old?
The Artist
PostPosted: 11:45 - 03 May 2010    Post subject: Reply with quote
Mine was 3 pin and I changed headlights and just guessed where the wires go. High beam is now low beam and vice versa but it works Laughing
Ichy
PostPosted: 15:03 - 03 May 2010    Post subject: Reply with quote
Three options according to the level of bodgery you wish to work on.
1. Cut off bulb connector, solder and heat shrink to new wires.
2. splice into original wiring and leave original connector on, 'just in case'.
3. Cut off bullet connectors and fit spades, push these into the original holder and tape up to stop them falling out.
I guess I'm a No.3 man Wink
The Artist
PostPosted: 17:41 - 03 May 2010    Post subject: Reply with quote
I am a number 4 man. I cut the wires and taped them to the new bulb holder with gaffa tape.
Misc
PostPosted: 00:38 - 04 May 2010    Post subject: Reply with quote
Thanks people,
I don't mind a bit of bodgery myself so i'll first twist the wires together until the new light comes on & operates correctly, then i'll either solder them in place or use some crimp connectors.
Don't mind about the low/parking beams. Always use high anyway night or day.
Ichy
PostPosted: 06:15 - 04 May 2010    Post subject: Reply with quote
They still need to work for the MOT
Misc
PostPosted: 12:33 - 04 May 2010    Post subject: Reply with quote
It's got fresh MOT for now but i'll swap them over if i have it by the next one.
Misc
PostPosted: 23:33 - 05 May 2010    Post subject: Reply with quote
Just wanted to ask,
I've bought the 2 headlights, both have 2 bulbs in & both have 3 wires. Do i connect 3 wires from the first headlight to the second & then connect the second to the stock headlight harness? (3 wires) Sure i don't need some kind of relay for this?
What's the best way to connect the 2 headlights together,should i just splice the wires together?
Cheers.
The last post was made 16 years, 176 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 71.04 Kb
