superbyke powerband 50
ozzyd1979
PostPosted: 18:33 - 03 May 2010    Post subject: superbyke powerband 50 Reply with quote
fuel isnt gettin into carb have to take fuel line off to get it into carb any ideas what the cause could be? thanks
OZZYD1979
johnsmith222
PostPosted: 18:36 - 03 May 2010    Post subject: Reply with quote
fuel tap?
ozzyd1979
PostPosted: 18:43 - 03 May 2010    Post subject: Reply with quote
nope theres a constant flow ive checked theres a 3 way fuel valve on it thats brand new theres no fuel tap thanks anyways
OZZYD1979
Blue_SV650S
PostPosted: 18:59 - 03 May 2010    Post subject: Reply with quote
You have to take the fuel line off to get fuel into the carburettor, I am confused as to what you mean by that!! Confused
ozzyd1979
PostPosted: 19:06 - 03 May 2010    Post subject: Reply with quote
i took fuel line off it ran through to cab then put bk on bike ran for a while then conked now it wont run again im stumped with this bike now Sad
OZZYD1979
Blue_SV650S
PostPosted: 19:21 - 03 May 2010    Post subject: Reply with quote
Sounds like there is a blockage in the carb ... get it taken off and stripped!! Thumbs Up
el_oso
PostPosted: 19:33 - 03 May 2010    Post subject: Reply with quote
if you have a shiTTy fuel pump or vacuum pump then you may need to crank the thing over a billion times before it can suck fuel from the tank, fill up the carb and then squirt it into the cyclinders.
try taking the spark plugs out and squirting a drop (and i mean a drop) of fuel into the cylinder.
Duke 390
Car: Jeep Wrangler 4.0L
JacPowell
PostPosted: 11:17 - 04 May 2010    Post subject: Reply with quote
Have you tried looking at your fuel cap ? There should be a small hole or pipe coming from it or elsewhere on the tank this it too allow air into the tank as the petrol is used this could create a vacuum and stop any petrol flowing to your carb. Just give it a blow too make sure its not blocked. Sometimes its just the really small things.
The last post was made 16 years, 70 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.95 - MySQL Queries: 13 - Page Size: 53.73 Kb
