Bike cuts out still ! After replacing about everything !
JacPowell
PostPosted: 10:51 - 04 May 2010    Post subject: Bike cuts out still ! After replacing about everything ! Reply with quote
Hi there, I was just wondering if anyone could help me, I have a 2004 Rieju MRX 50, its got a minarelli AM6 engine in it the same as the aprillia rs 50 so im hoping someone will know what im on about ! Anyway its had a 70cc cylinder kit put on it and i took it to a bloke after a few weeks of buying it because it would randomly just bog down for no reason he said it was the head gasket so i got him too do the head gasket jumped on it took it for a spin and it still bogged down so he kept it too have a look and said its your carb pulling in air through the choke inlet on the carb as the choke was removed so i bought a choke lever and plunger set and he fit it started up first kick no problem took it for a spin and it still bogged down so he said the only other thing it can be is the exhaust (original, rusty, crap) so i bought a fancy new sports exhaust and de-ristricted it and put that on myself took it for a spin it didnt cut out so i went for a long ride and bam it cut out again ! so another friend recommended a new unrestricted CDI unit so i bought one put it on and it still cuts out, i took it back too the bloke he stripped by carb down for the 4th time and he said the jet needs too be higher but after he stripped it it ran like a beauty for 2 days pulling cleanly, and then on the 3rd day of loving my bike not having to be on the side of the road kicking the damn thing over it cut out on me Sad so after all this money spent i still have a bike that cuts out, im just not sure weather to change the jet or buy a bigger carb id prefer too do the jet but what would it be upgraded to ? Its a Dellorto PHBN12 HS Carburettor and its currently jetted to 72 but that was before the exhaust and CDI and have been told it will need to go up anyway because of the exhaust and CDI. Sorry for this rather long boring post but im hoping somebody will take there time too read this and offer some advice and if that person is you, thankyou very much it is highly appreciated.
Damon
PostPosted: 11:08 - 04 May 2010    Post subject: Reply with quote
My friend had a similar prolem. It was his electrical system not working properly. A new HT lead, coil, plug and alternator later and it worked fine.
Start simple and check your plug. what does the tip it look like?
JacPowell
PostPosted: 11:09 - 04 May 2010    Post subject: Reply with quote
Plugs fine not too rich or too lean, theres a nice blue spark coming from it too.
JacPowell
PostPosted: 13:46 - 04 May 2010    Post subject: Reply with quote
Just been too have a look and now it wont even go to high revs theres now a sort of deep loud throaty noise from the exhaust. Thanks
finpos
PostPosted: 14:40 - 04 May 2010    Post subject: Reply with quote
the problem is clearly that you have a shit mechanic and a trusting nature.
f.
TUG
PostPosted: 16:44 - 04 May 2010    Post subject: Reply with quote
Didn't someone off here have running problems down to the side stand kill switch cutting the bike out?
Haz ER-5, innit!
JacPowell
PostPosted: 16:46 - 04 May 2010    Post subject: Reply with quote
Hi there, thanks for your reply but i have already checked for kill switches and there are none.
TUG
PostPosted: 16:47 - 04 May 2010    Post subject: Reply with quote
Suicide stand?
Ah well, are you sure the plug is a tanned brown?
Haz ER-5, innit!
JacPowell
PostPosted: 16:50 - 04 May 2010    Post subject: Reply with quote
Yes the plug is tanned brown, i was thinking it may be the stator but it cant be as it ran fine for 2 days. Im so confused and frustrated ! :S Sad
TUG
PostPosted: 16:54 - 04 May 2010    Post subject: Reply with quote
I don't know what to suggest, Battery terminals are tight? your earth is tight on the engine/frame?
Haz ER-5, innit!
JacPowell
PostPosted: 16:55 - 04 May 2010    Post subject: Reply with quote
It doesnt have a battery it has a generator and the CDI earth is secure as i only just fit it the other day. Thanks
Nemo
PostPosted: 17:05 - 04 May 2010    Post subject: Reply with quote
It will have a battery, all the generator does is create the spark, the battery runs all the lights and what not, there isn't a vehicle on the road without a battery, it needs it to work Neutral
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
cloric_tzr
PostPosted: 17:09 - 04 May 2010    Post subject: Reply with quote
not quite tru older bmw 3 series will run without a battery very hard to start without 1 but if u gt a mate willing enuf to tow start u ur away
i dumped my girlfriend the other day! she wouldnt act out one of my fantasy's. all i wanted her to do was come home from work, catch me fucking her sister and join in!!! miserable bitch!
My wifes so ugly, the only thing that goes down on her
Is the internet connection.
JacPowell
PostPosted: 17:15 - 04 May 2010    Post subject: Reply with quote
Quoting from the manual, ' There are a number of coils in the Generator one produces A.C. volts to power the lights,horn and indicators. The other coil is responsible for picking up a signal to provide the spark for the ignition system.'
Nemo
PostPosted: 17:26 - 04 May 2010    Post subject: Reply with quote
huh, never heard of that before, I stand corrected...maybe it's a problem with the generator then?
JacPowell
PostPosted: 17:29 - 04 May 2010    Post subject: Reply with quote
I was thinking that but would it run fine for 2 days with a dodgy generator ?
Nemo
PostPosted: 17:43 - 04 May 2010    Post subject: Reply with quote
Hmmm wouldn't have anything to do with the revs I spose, I take it you've checked the fuel pipe make sure it's not blocked anywhere, oil pump maybe but I can't see it being that, could be the timing?? That has something to do with the generator
JacPowell
PostPosted: 17:44 - 04 May 2010    Post subject: Reply with quote
Iv just updated the fuel line and re-routed it so there are no kinks, and its running pre-mix so it isnt the oil pump. And the timing is in the CDI box which i have just replaced also.
Damon
PostPosted: 17:48 - 04 May 2010    Post subject: Reply with quote
I would try the HT lead and plug as said earlier. It may be sparking ok but it all changes at higher revs and under load.
And sack your mechanic too. Rolling Eyes
Nemo
PostPosted: 18:15 - 04 May 2010    Post subject: Reply with quote
so the generator creates the volt then sends it to the CDI? Sorry I'm not much help but I've only dealt with classic and more 'simple' bikes, can you plonk the cdi straight in without having to adjust anything then?
JacPowell
PostPosted: 18:16 - 04 May 2010    Post subject: Reply with quote
Cheers guys, the plan is to get a new generator and try that and if not a new ht lead and cap. If all that fails who knows what ill do with it.
Nemo
PostPosted: 18:25 - 04 May 2010    Post subject: Reply with quote
Try the HT leads and plug first, as it's the cheapest option, if it's not that then your safe in the knowledge you won't have to do it for a while, how much money have you spent on it so far?
pepperami
PostPosted: 18:54 - 04 May 2010    Post subject: Reply with quote
have you thought about the plug-cap? as some have a resistor in them? and that can break down and cause a few sparking problems, it may only show itself at higher revs or when the engine is fully warm and been running for a while?
the exact same is true of coils
just an idea Smile
JacPowell
PostPosted: 19:04 - 04 May 2010    Post subject: Reply with quote
Bike cost £400
MOT £30
Tax £15
New Chain and Sprockets £ 50
New indicator lights £25
New exhaust £180
New CDI £40
New Brake pads £15
New Spark plugs £20
New Head gasket £10
Choke assembly £15
New Speedo cable and Drive £50
Labour £140
Flywheel puller tool £15
Toolbox £50
Petrol £40
Insurance £300
Which comes to a grand total of £1395 for a 2004 bike with about 2000 miles on it, which as it stands cant even get me too the shops and back. Sad
JacPowell
PostPosted: 19:07 - 04 May 2010    Post subject: Reply with quote
CHR15 wrote:
jesus, sounds like youve spent a lot of money.
have you even done a plug chop yet?
run it till it bogs and as soon as it does, clutch in kill it and have the spark plug out. then check the colour.
dont bother replacing things till youve tracked down the problem.
so, it bogs down under load. but not always. and sometimes it cuts out.
firt thing to do is have a good look at your ht lead. make sure its not damaged anywhere, then make sure its routed so it doent touch anything metal.
have a good look at all the contacts going into the cdi unit, make sure there clean and well attached.
if there all ok, take it out, and when it cuts out, open the petrol cap, while listening for any hissing / vaccum noises.
does it have the stick airbox? is the air filter clean and ok?
what ratio pre-mix are you running it on?
Yes it was tan like it should be, HT lead is in good condition not touching any metal. All connections too the CDI are fine as i have only just replaced it. Not sure what you mean by the stick air filter but iv had it out and cleaned it all thoroughly with petrol and oiled the filter. Im putting in 125ml Castrol TTS in 5 Litres of Super Unleaded Petrol.
The last post was made 16 years, 52 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 3.15 - MySQL Queries: 15 - Page Size: 123.2 Kb
