My bike cut out on the duel carriageway!
StevenF
PostPosted: 23:14 - 03 May 2010    Post subject: My bike cut out on the duel carriageway! Reply with quote
Don't know what happened, was sitting at 70 and the bike seemed to 'choke', "running low on fuel I though". Switched it over the reserve but it kept on coughing a little and just felt like it had died. I was hoping it was fuel and the reserve would kick in, but it didn't Sad It slowed to a stop in the slow lane of the duel carriageway.
For some reason it started up about 30 seconds later and seemed fine. I didn't think it was low on fuel either but I kept it on the reserve anyway.
When switching over to the reserve tank, should the fuel start flowing straight away or does it take a while? I was wondering if it just took a while for the fuel to get through the lines, but I thought it would be instantly.
Any ideas why this could have happened?
Cheers,
Steven
Nemo
PostPosted: 23:25 - 03 May 2010    Post subject: Reply with quote
If it's a fuel pump rather than relying on gravity, I would have thought it would be instant, even the gravity way is pretty quick, unless there's like an air lock or something
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
tutton
Takes a while to switch on some bikes,
have sat for a good 30 seconds before its primed enough to start on the fzr.
SCHOT_NSR
PostPosted: 12:07 - 04 May 2010    Post subject: Reply with quote
hi i had this problem once as i never run low on fuel one day i was out on a run bike started to choke and cough and it stoped put it on reserve still nothing tried it again and away it went thought it mite be all the crap in the tank settling at the bottom clogging the reserve all up
if everything around you seems to be going well you obviously aint got a clue whats happening
PostPosted: 12:11 - 04 May 2010    Post subject: Reply with quote
I had a GS with a dodgy fuel tap, sometimes the main/res stopped working as the vacuum pipe to the carb was split.
I ended up using "prime" to get home.
Paxovasa
PostPosted: 12:27 - 04 May 2010    Post subject: Reply with quote
When changing to reserve on the bandit it is pretty instant, when changing over on the Xt it usually takes 30 seconds.
Does sound like it just took a while for the fuel to get through to the carbs.
theopj
PostPosted: 13:09 - 04 May 2010    Post subject: Reply with quote
My Honda takes about 30 seconds (carbs) - i've had it cut out a few times just like you describe, then starts up again once you have left it a bit. It is a pain when you don't have a fuel gauge so you have to keep an eye on the miles you've done.
Suzuki Bandit SA 1250 & Honda CB750F2T
cloric_tzr
PostPosted: 13:50 - 04 May 2010    Post subject: Reply with quote
i forgot to switch my fuel tap on my tzr the other day from petty station just got on the duel an she died i managed to fumble and find the tap whiles coasting along and she fired up pretty much instant once i dumped the clutch. gota much bigger problem now!!!
i dumped my girlfriend the other day! she wouldnt act out one of my fantasy's. all i wanted her to do was come home from work, catch me fucking her sister and join in!!! miserable bitch!
My wifes so ugly, the only thing that goes down on her
Is the internet connection.
ajbsmirnoff
PostPosted: 19:31 - 04 May 2010    Post subject: Reply with quote
The first time* I ran out and changed to reserve it took a few seconds (zx6r) for the reserve to work. Seemed like alot longer though.
*new riders' schoolboy error
Dazbo666
PostPosted: 20:52 - 04 May 2010    Post subject: Reply with quote
Usually switches over within seconds on the Bandit ... and similar with the GPZ, from memory.
For me it's only happened once on each bike, just until I learn the point that it's likely to happen, then fuill up before the tank gets too low. Thumbs Up
Word of the day : DILLIGAF
cb1rocket
PostPosted: 21:21 - 04 May 2010    Post subject: Reply with quote
another problem could be due to a block fuel tank vent, you can tell when you hear air rushing in as you take the cap off for filling up
Thom
PostPosted: 10:12 - 05 May 2010    Post subject: Reply with quote
my old gs500 had twin pipes coming from under the fuel tank leading to the tap, when turning it onto reserve there was often a delay as the reserve hose was dry so it took a few seconds for fuel to flow properly - i solved it by finding a Y shaped fuel hose which meant the reserve and main fuel worked on the same hose, in my mind allowing some fuel to always remain in the hose.
The last post was made 16 years, 53 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.46 - MySQL Queries: 13 - Page Size: 72.35 Kb
