YBR starting - Choke every time
squishio
PostPosted: 14:33 - 04 May 2010    Post subject: YBR starting - Choke every time Reply with quote
Hi All
I just bought my Gf a YBR125 and have discovered that it needs the choke to start every time.
Now, it's been a while since I rode a 125 but I don't remember having to have the choke on every time no matter how cold/warm the weather is.
It starts perfectly on the button without choke, but if you try to rev it it just dies.
stick the choke on, it idles high as you would expect and after about a minute you can turn the choke off and it revs freely and happily.
Is that normal? I can understand on a cold morning having to use the choke btu on a hot summers day as it has been recently you still have to do it Confused
the bike is a 2005 ybr, the carb has 2 wires going to it, I haven't got a clue what these do, just want to know out of interest TBH Smile
is it worth cleaning the carb out?
Cheers!
Rich
Current - Hornet 600, Transalp 650, X140 Pit, GPZ400R
Past - SY125, GT250, GT650, CX400, CBF600, Bandit 600, SL1000, GT250
neil.
PostPosted: 15:02 - 04 May 2010    Post subject: Reply with quote
Sounds normal to me. Mine has always taken a few minutes to warm up before it will return to idle after revs without cutting out. Even in this warmer weather, I find I need the choke for a minute or so before the bike will idle properly. It's been like that since I bought it 2 years ago and I've put 26'000 miles on her since then. You could try adjusting the idle screw on the carb a little bit to raise the idle speed but if it's sitting at 1500RPM when fully warm (after a long fast ride) then leave it be.
Edit - the wires are the electrical connection to a heating element that comes on below 16 degrees Celsius to evaporate moisture and stop the carb icing.
Alexio
PostPosted: 15:23 - 04 May 2010    Post subject: Reply with quote
I take it these bikes destroy their battery if left connected during the winter months then?
neil.
PostPosted: 15:28 - 04 May 2010    Post subject: Reply with quote
No, it only comes on with the ignition. Thumbs Up
The last post was made 16 years, 65 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.48 - MySQL Queries: 13 - Page Size: 41.39 Kb
