| Blackwolf |
 Blackwolf Burgerfist
 Posted: 11:01 - 04 May 2010 Post subject: Building a PC |
I dont know much about building a PC, been looking at websites to build your own.
Was wondering here if anyone knows if this is a good spec? Should i make any changes?
Its for gaming, general PC stuff, and proberly some CAD work.
Anyone here good at building them? or even have Windows 7 lurking about
Looking to spend about 900-1K
Also, graphics cards... been out the loop for a while... is the one I have any good? or is it worth Changing? anyone know any good sites for getting components/cheaper companys to build them/Anyone here built a lot?
Processor (CPU)
Intel® Core™i7 Processor i7-930 (2.80GHz) 4.8GTs/8MB Cache
Motherboard
ASUS® P6TD DELUXE, EXTREME OVERCLOCKING, SLI & CROSSFIREX
Memory (RAM)
6GB CORSAIR XMS3 TRI-DDR3 1600MHz - LIFETIME WARRANTY
Graphics Card
1GB ATI RADEON™ HD 5750 PCI EXPRESS - DirectX® 11
Memory - 1st Hard Disk
250GB SERIAL ATA 3-Gb/s HARD DRIVE WITH 8MB CACHE (7,200rpm)
1st DVD/BLU-RAY Drive
24x DUAL LAYER DVD WRITER ±R/±RW/RAM
Power Supply & Case Cooling
600W Quiet Quad Rail PSU + 120mm Case Fan (£59)
Processor Cooling
INTEL SOCKET LGA1366 STANDARD CPU COOLER
Sound Card
Sound Blaster® Audigy™ SE (£25)
Network Facilities
ONBOARD 10/100/1000 GIGABIT LAN PORT
USB Options
6 x USB 2.0 PORTS @ BACK PANEL (MIN 2 FRONT PORTS) AS STANDARD
Operating System
Genuine Windows 7 Professional 64 Bit - inc DVD & Licence (£108)
For that build i have been given a price of £1088
That good?
Same with mother boards, Intel or AMD?
Cheers for help!  ____________________ Current: Ducati Multistrada 1200s
| Blackwolf |
 Posted: 11:12 - 04 May 2010 Post subject: |
Compaired to this build?
* Gigabyte GZ-X1 Black ATX MIDI Tower Case
* ASUS P6T: 6x Rear USB2.0: 2x Front USB2.0: 1x Rear Firewire
* Intel® Core™ i7 930 2.8GHz
* Thermaltake TR2 500W PSU
* Standard CPU Cooling Fan
* Corsair XMS3 6GB (3x2GB) DDR3 1600MHz
* 500GB 7200RPM SATA II
* 22x DVD RW Black SATA
* ATI Radeon HD 5770 1GB
* Microsoft Windows® 7 Professional 64-bit
* Built-in audio
Some stuff I know about, other not. just looking for some people with better knowlage  ____________________ Current: Ducati Multistrada 1200s |
| L4Isoside |
 L4Isoside World Chat Champion
| Blackwolf |
 Posted: 11:52 - 04 May 2010 Post subject: |
The only thing with the other sites is that they build it, knowing my luck i will undoubtdly somehow make some static and fry the component
As for the HDD is there any differnce using say 2X250GB instead of 1 500GB?
I will be using a Removabe HDD too ____________________ Current: Ducati Multistrada 1200s |
| Pernig |
 Pernig World Chat Champion
| Blackwolf |
| Neorion |
 Neorion World Chat Champion
| Blackwolf |
| Welshd1k |
 Welshd1k World Chat Champion
| Blackwolf |
| Neorion |
| Blackwolf |
 Posted: 15:34 - 05 May 2010 Post subject: |
https://www.pcspecialist.co.uk/images/products/1870/1_big.jpg
TITAN FENRIR TTC-NK85TZ/V2
Fenrir-TTC-NK85TZ has many rich characteristics; comparing with the original heat pipe size at 6mm, Fenrir possesses 4 larger 8 mm diameter copper heat pipes with the direct touch design to maximize the overclocking performance up to 160W and succeed in offering the best cooling performance. The 12cm giant fan with built-in PWM speed control technology will operate automatically to solve overheating problems and provide a silent environment.
The Fenrir, especially suitable for Intel LGA1366 and LGA 1156 (TTC-NK85TZ/V2) is absolutely the best thermal solution for your computer.
Hows that? better or not? im trying to avoid buying things and adding them on.
Cheers for help so far guys.  ____________________ Current: Ducati Multistrada 1200s |
The last post was made 16 years, 133 days ago. Instead of replying here, would creating a new thread be more useful? |
