Aprilia rs 125 clutch problem !
reality29
PostPosted: 15:21 - 06 May 2010    Post subject: Aprilia rs 125 clutch problem ! Reply with quote
Hi everyone ! I have an Aprilia rs 125 2005 and half year ago the clutch started to slip when i tried to accelerate fast at high revs. In the beginning, the slipping was small and after a week or two it became hard to ride. Now I bought new (original ROTAX) Friction Clutch Plates, Steel Plates, a Set Of Heavy Duty Springs and gearbox oil. I changed everything according to the rotax engine repair manual and everything seemed to be fine until I drove it... I can't believe even now, after changing everything - no effect ! The clutch slips as before. Please, maybe someone could help me !
PostPosted: 20:05 - 06 May 2010    Post subject: Reply with quote
Have you adjusted the clutch? There is an adjuster in the middle of the clutch cover.
reality29
PostPosted: 20:23 - 06 May 2010    Post subject: Reply with quote
Yeah, I have tried to adjust with both, the screw and the lever but nothing Sad
stirlinggaz
PostPosted: 20:56 - 06 May 2010    Post subject: Reply with quote
which gear oil are you using?
& have you tried changing the clutch cable?
cheers,
GAZ
reality29
PostPosted: 09:18 - 07 May 2010    Post subject: Reply with quote
Gearbox oil 75W80 full synthetic. The clutch cable is almost broken in one place (near the hand lever) but I don't know if this problem is because the cable or is it ?
PostPosted: 11:11 - 07 May 2010    Post subject: Reply with quote
It could be. Depends if the cable sticks.
PostPosted: 11:32 - 07 May 2010    Post subject: Reply with quote
What did the old clutch plates looks like where they worn? I can;t imagine a RS125 living long enough to go through a Clutch TBH, I would get a new cable.
The last post was made 16 years, 97 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 51.95 Kb
