2-stroke oil feed pipe.
PostPosted: 21:38 - 06 May 2010    Post subject: 2-stroke oil feed pipe. Reply with quote
Will it matter if i use a oil pipe that is about 1mm thinner in (inner) diamater than the original?
I'm talking about the thin pipe which goes from the oil pump to the carb btw.
You can't buy the genuine oil pipe from yamaha anymore which is a bit annoying Confused
Can't wait to get out and test ride the bike after being off the road for so long but i'm taking no chances Laughing
Thanks
Dave
DRZ-400sm
Quote Me Happy
PostPosted: 21:40 - 06 May 2010    Post subject: Reply with quote
If you know the diameter of the pipe can't you just buy some generic pipe?
PostPosted: 21:45 - 06 May 2010    Post subject: Reply with quote
Been everywhere and no-one sells it! this stuff i have now is the closest i could find which was from a lawnmower shop.
The outer diamater has to be fairly exact aswell as it passes through a rubber bung.
DRZ-400sm
PostPosted: 21:46 - 06 May 2010    Post subject: Reply with quote
The oil pipe is normally a very small bore pipe. Would expect a 1mm difference to be a hell of lot.
You should be able to get some replacement pipe.
Try this
PostPosted: 21:56 - 06 May 2010    Post subject: Reply with quote
Thanks keith,i'll contact them for the outer diamater size.
This clear pipe doesn't seem as strong as the original yamaha pipe which is what's putting me off.
It's quite a tight fit through the rubber bung and if the pipe is too weak it might cut the flow aswell.
DRZ-400sm
The last post was made 16 years, 98 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.85 - MySQL Queries: 13 - Page Size: 47.61 Kb
