1990 JC20 ALCAST HONDA NSR 125 STARTING PROBLEMS!!
DANNYBOI
PostPosted: 20:29 - 06 May 2010    Post subject: 1990 JC20 ALCAST HONDA NSR 125 STARTING PROBLEMS!! Reply with quote
Mad I HAVE A HONDA NSR 125CC JC20 ALCAST VERSION WITH STARTING PROBLEMS THE STARTER DIED SO THAT GOT REPLACED NOW THE BIKE JUST WILL NOT START IT TURNS OVER AND SPARKS AS IT SHOULD THE COMPRESSION IS FINE ANY IDEAS
NSR YEHA
Tattoo Artist
PostPosted: 20:41 - 06 May 2010    Post subject: Reply with quote
try not typing in bold, may help?
DANNYBOI
PostPosted: 20:46 - 06 May 2010    Post subject: Reply with quote
Very Happy sorry lol just about to crack with this it all sounds as if its wanting to fire up but just will not go!!! Sad
NSR YEHA
cloric_tzr
PostPosted: 21:16 - 06 May 2010    Post subject: Reply with quote
have you switched the petrol on? Very Happy
i dumped my girlfriend the other day! she wouldnt act out one of my fantasy's. all i wanted her to do was come home from work, catch me fucking her sister and join in!!! miserable bitch!
My wifes so ugly, the only thing that goes down on her
Is the internet connection.
DANNYBOI
PostPosted: 21:24 - 06 May 2010    Post subject: Reply with quote
yes petrol on new spark plug new petrol cleaned airfilter ect
NSR YEHA
cloric_tzr
PostPosted: 22:51 - 06 May 2010    Post subject: Reply with quote
av u tryed bumping her?
SCHOT_NSR
PostPosted: 14:38 - 07 May 2010    Post subject: Reply with quote
is your battery charged i had a problem similiar so i stuk the charger on it and away it went just an idea mite be talkin rubbish but it worked for me lol
if everything around you seems to be going well you obviously aint got a clue whats happening
Tattoo Artist
PostPosted: 17:22 - 07 May 2010    Post subject: Reply with quote
try putting a little fuel down spark plug hole and see if she runs for a few seconds, then checck fuel tap, fuel lines, check jets in carb arent blocked, check reeds are opening properly, check battery, check all of this then get back to me
skatefreak
PostPosted: 18:02 - 07 May 2010    Post subject: Reply with quote
Try bump starting the bike,
i know this dosnt sound like it makes much sense but for no
perticular reason my nsr is not to happy starting on the starter at the moment (will crank over for ages but not fire)
however give her a push, drop the clutch and she will start up the second i drop the clutch (dosnt make much sense really lol).
-Jvr
DANNYBOI
PostPosted: 19:46 - 07 May 2010    Post subject: Reply with quote
SHE BUMPS GOES FOR A MINUTE THEN CHOKES UP AND DIES
THERES A NEW BATTERY IN IT JUST CHARGING ATM IT WAS AT 10.5 VOLTS
IT ALL TURNS OVER AND TRYS TO BUT JUST WILL NOT GO
NSR YEHA
skatefreak
PostPosted: 20:09 - 07 May 2010    Post subject: Reply with quote
Sounds like there is a restriction in the fuel getting to it.
If there is a blockage or tap isnt open (my experience) etc then the engine will fire up and rev up to maybe k1 but then just die off...
I know it dosnt help much but i'd suggest looking at fuel getting to the carb however, does the engine idle normally or does it sound different (deeper/hollow). can you rev the engine atall? throttle response?
-Jvr
DANNYBOI
PostPosted: 20:11 - 07 May 2010    Post subject: Reply with quote
no mate it just starts and dies
NSR YEHA
skatefreak
PostPosted: 20:16 - 07 May 2010    Post subject: Reply with quote
open the throttle and it just makes a louder noise but not effect the throttle by any chance?
Certainly sounds to me like fuel not getting to it Neutral
Got that many times forgetting to open the fuel tap after first getting her heh.
Check fuels getting to get,
get onto nsr.co.uk and pick up a manual, take pictures and throw up a post around here if you have any troubles!
best regards
-Jvr
DANNYBOI
PostPosted: 18:02 - 23 May 2010    Post subject: UPDATE Reply with quote
ENGINE TURNS OVER SPITS FIRE OUT EXHAUST PORT ALL SOUNDS AS IF WANTS TO GO COULD IT BE BECAUSE THERES ASDA 2 STROKE OIL IN IT Embarassed
NSR YEHA
DANNYBOI
PostPosted: 19:36 - 11 Jun 2010    Post subject: Reply with quote
bike still no change engines out of bike in shed all conected up had new gearoil new petrol and new plug no change turns over and over splutters every once in a wile but no start"!!
NSR YEHA
skatefreak
PostPosted: 12:22 - 12 Jun 2010    Post subject: Reply with quote
I wouldnt have thought that the 2 stroke asda oil would stop the bike from running, it may cause the bike to blow up if its been run on it hard for a while but shouldnt cause starting problems...
What are the symptoms at the mo.
Is the engine firing, trying to fire or just turning over with no signs of life?
-Jvr
DANNYBOI
PostPosted: 17:45 - 12 Jun 2010    Post subject: Reply with quote
TURNS OVER AND OVER TRIES TO FIRE EVERY SO OFTN
NSR YEHA
baldy
PostPosted: 19:55 - 12 Jun 2010    Post subject: Reply with quote
Sounds like it needs new piston and rings. I have had 4 bikes that did exactly that due to the rings being fudged.
How did you test the compression? Did you use a compression tester?
One day i will rule the world, just not today.
The last post was made 15 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 95.8 Kb
