Scottoiler issue
Welshd1k
PostPosted: 23:24 - 06 May 2010    Post subject: Scottoiler issue Reply with quote
i have a stock Scottoiler atm and only half my chain seem's to be getting lubed.... so i wa slookign at dual injector kits but then saw the 'slipper brick ' for £14 deliverd so i have ordered one. but the question is why did my oiler only oil half the chain was it positioned wrong because now thinkign about it it seems daft if it was only lubign half the chain ...
was positioned like this
https://www.drainfade.com/pics/scottoiler/scottoiler_delivery2.jpg
seems daft only oiling half
Itchy
PostPosted: 23:26 - 06 May 2010    Post subject: Reply with quote
Because the nozzle is only on one side of the chain, for all their talk about it leeching to the other side of the chain it doesn't unless you place the nozzle above the chain which I did for a while when it broke in spain.
Incidentally the scotoiler kit comes with a T piece you can use with a couple of cable ties to form a two sided oiler if you really want to.
Peirre oBollox
PostPosted: 10:04 - 07 May 2010    Post subject: Reply with quote
Wouldn`t the setup benefit from the nozzle being sited further forward to the front of the sprocket?
Walloper
PostPosted: 11:33 - 07 May 2010    Post subject: Reply with quote
The instructions for the oiler are clear. The injector should mount in front of the sprocket.
A dual injector is best for not much cost.
bathtub
PostPosted: 13:29 - 07 May 2010    Post subject: same here Reply with quote
My oiler is the same, I am not worried about how it looks and I use the bike daily - works for me as not had to adjust since purchased.
https://lh4.ggpht.com/_mZmNL3U6hrw/S6NMaepjtyI/AAAAAAAAGRE/wRD00vHtT9I/s1600-h/chain-detail%5B2%5D.jpg
bathtub
That_Hornet
PostPosted: 13:37 - 07 May 2010    Post subject: Re: same here Reply with quote
bathtub
Snap Wink
DrDonnyBrago
PostPosted: 14:10 - 07 May 2010    Post subject: Reply with quote
Mine is a single sided nozzle like yours, however my chain is littered with stuck links and is due replacement...
I am looking into bodging a dual nozzle outlet for it to protect both sides of the new chain.
EDIT: wtf is a slipper brick?
njd27
PostPosted: 14:23 - 07 May 2010    Post subject: Reply with quote
Slipper block, you mean.
It fits all the way around the chain and attaches to the bottom of the swing arm:
https://www.scottoiler.com/slipperblock-system.asp
Kris
PostPosted: 14:25 - 07 May 2010    Post subject: Reply with quote
If your flow rate and applicator position are set correctly then both sides of the chain will recieve oil eventually, even though it is only directed at the outside with the nozzle. Don't ask me how - it just happens! Very Happy
My setup on the SV
https://www.bikechatforums.com/files/scot_011.jpg
www.prisonplanet.com
The last post was made 16 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 61.67 Kb
