| Misc |
 Misc World Chat Champion
| Bru |
 Bru Trackday Trickster
 Posted: 22:07 - 07 May 2010 Post subject: |
| Misc |
 Posted: 22:28 - 07 May 2010 Post subject: |
Nice one, thank you.
Can i use one type of wire for everything i.e ground, positive, negative etc? |
| oldbiker |
 oldbiker Nitrous Nuisance
 Posted: 08:02 - 08 May 2010 Post subject: |
In general you should allow 1 square mm of conductor area for each amp of current that the wire will be carrying.
from Ohms law current(Amps) = Voltage/resistance(Ohms)
power = voltage x current
or current(Amps) = Power (watts rms)/Voltage
example a 50 watt lamp supplied by a 12v supply.
Current = 50/12 =about 4.2 amps use wire that has a cross sectional area of more than 4 square mm.
When I use wire for a bike I always buy multi strand wire the finer the strands the more flexible the wire is. The greater the number of strands the better.
For most general wiring I use 32 strand 0.2 tin coated wire. That will handle about 6 amps or 72 watts.
the tin coating helps to prevent corrosion of the copper and costs very little extra.
The link provided by Bru, is for a very good dealer, but you could also try Maplin, RS components, Farnell, or CPS, all on the net ____________________ It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg |
| Ichy |
 Ichy World Chat Champion
| G |
 G The Voice of Reason
| Dazbo666 |
 Dazbo666 World Chat Champion
| Misc |
 Posted: 12:42 - 08 May 2010 Post subject: |
Brilliant guys. Thank you all. Makes much more sense now.
There isn't anything wrong with using thicker wire then you need tho, i.e a 1 inch thick wire for a single indicator?
tzr.steve: When you said about a " 50/12 =about 4.2 amps, use wire that has a cross sectional area of more than 4 square mm. " I'm a bit confused because on the VWP website a 4.5mm2 wire would be 35amps.
| nick606 |
 nick606 World Chat Champion
| oldbiker |
| nick606 |
| oldbiker |
The last post was made 16 years, 167 days ago. Instead of replying here, would creating a new thread be more useful? |
