Which drill sizes to use when tapping a thread?
Raffles
PostPosted: 15:17 - 08 May 2010    Post subject: Which drill sizes to use when tapping a thread? Reply with quote
When tapping a 5mm thread and a 6mm thread into aluminium which respective drill sizes should I use?
hmmmnz
PostPosted: 15:32 - 08 May 2010    Post subject: Reply with quote
go down 1mm on both
its actually 4.2 for a 5mm but 4 is fine
the humans are dead
I kick arse for the lord
Blue_SV650S
PostPosted: 15:47 - 08 May 2010    Post subject: Re: Which drill sizes to use when tapping a thread? Reply with quote
M5 = 4.2mm drillbit
M6 = 5mm drillbit
Raffles
PostPosted: 16:48 - 08 May 2010    Post subject: Reply with quote
Thank you boys, very much helpfull. There's some Thumbs Up heading your way.
Nufkamp
PostPosted: 21:48 - 08 May 2010    Post subject: Reply with quote
For other thread sizes go here
https://www.simetric.co.uk/sidrill.htm
As seen on Google Street View https://tinyurl.com/yfdvojc
V2
PostPosted: 23:09 - 08 May 2010    Post subject: Reply with quote
Just look on the side of the tap and if it says M5 X 0.8 then 5-0.8 = 4.2mm , M6 X 1.0 then 6-1= 5mm etc
steven_191
PostPosted: 23:13 - 08 May 2010    Post subject: Reply with quote
Here's a good guide I've found easy to remember. Only a guide tho. You subtract the the thread pitch from the bolt size you want. Eg m6x1.25. So you would drill 4.75mm. I think the equivilent is 4.8mm.
V2
PostPosted: 23:15 - 08 May 2010    Post subject: Reply with quote
https://static.rcgroups.com/forums/attachments/2/7/7/9/3/9/a2926156-219-Facepalm%20jesus-facepalm-facepalm.jpg
oldbiker
PostPosted: 23:45 - 08 May 2010    Post subject: Reply with quote
This is correct for all iso threads, that is any thread with a 60 degree angle on the thread profile . so for any metric or ba thread subtract the pitch from the diameter.
well done steven_191 you are awarded top marks for this weeks class
It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg
The last post was made 16 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 59.39 Kb
