Bloody brakes
Karl Bird
PostPosted: 12:32 - 09 May 2010    Post subject: Bloody brakes Reply with quote
I have tried everything that i've read on the BCF to bleed my front brake and it's still not as firm as i'd like. Any ideas before i kill something.
Itchy
PostPosted: 12:46 - 09 May 2010    Post subject: Reply with quote
What did you do?
You're probably not bleeding it correctly.
Here is what you can do to get the last bit of air out, grab the caliper and shake it and shake the pipes as well. A subsitute for this (with the master cylinder cap on) is to put the front brake on and push t he bike forward maing the forks dip which has a similar effect.
The last of last bubbles is often like fizzy drink bubble size.
Just bleed them the normal way at the caliper, remembering to top up master cylinder, then repeat at the top (which just means lots of in out of the brake lever) and you might see a tiny column of air bubbles rising up from the hole in the master cylinder.
Karl Bird
PostPosted: 13:07 - 09 May 2010    Post subject: Reply with quote
I'm gonna take it for a spin now which will have the same effect i suppose then try try try again thanks for the reply.
woll
PostPosted: 13:09 - 09 May 2010    Post subject: Reply with quote
Try just taking the reservoir cap off and then pumping the brake, sometimes this can bring a lot of the little bubbles out, or try tying the brake lever to the handle bars and leaving it for a while but keep an eye on the level.
Charlie
PostPosted: 14:44 - 09 May 2010    Post subject: Reply with quote
Clamp the brake on as hard over night. In the morning release the brake and see if it has firmed up. It has worked on my bike before.
temeluchus
PostPosted: 15:08 - 09 May 2010    Post subject: Reply with quote
Use a big syringe and some hose to draw fluid and air throught the system at the bleed nipple. Just remember to have a pal top up the reservoir for you as it goes through quick! Takes about 10 minutes to bleed brakes this way.
Karl Bird
PostPosted: 16:08 - 09 May 2010    Post subject: Reply with quote
Been out for a spin. The brake is good bled it when i got back no more air came out. I think it's as good as it gets
The last post was made 16 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 52.9 Kb
