new tyre vs part worn
Mr White
PostPosted: 13:39 - 09 May 2010    Post subject: new tyre vs part worn Reply with quote
I need a rear tyre.
But I dont have a spare £90 for a new one (+ service charge)
I was looking at part worn tyrs, complete with wheel on ebay.
I asked sellers about the amount of thread left
Complete rear wheel £40 delivered- 5mm thread left
Set of complete wheels £85 delivered - 1.2mm but descirbed as 'lots of thread left', asked him if he ment 12mm, he apologized and said that he ment 12mm.
Rolling Eyes How much thread is on a brand new standard, road bike tyre.
Barry_M2
PostPosted: 14:48 - 09 May 2010    Post subject: Reply with quote
It won't have 12mm tread unless it's a crosser?
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
temeluchus
PostPosted: 15:06 - 09 May 2010    Post subject: Reply with quote
What bike is it?
DrDonnyBrago
PostPosted: 15:53 - 09 May 2010    Post subject: Reply with quote
As above... 12mm... really??
Most new "road" tyres come with about 5-7mm tread.
Mr White
PostPosted: 16:32 - 09 May 2010    Post subject: Reply with quote
Temeluchus wrote:
What bike is it?
Its Yamaha XJ600
Mr White
PostPosted: 16:41 - 09 May 2010    Post subject: Reply with quote
It was described as 'lots of thread left' I believe 1.2mm isnt road safe, so I suggested him 12mm.
I asked him to take a pic but he never got back to me Mr. Green
My current,perished Sad tyre has 8mm left
https://mc.bridgestone.co.jp/en/products/battlewing/index.html
Will go for 5mm one then Thumbs Up
Mr White
PostPosted: 13:45 - 10 May 2010    Post subject: Reply with quote
UPDATE
The 1.3mm / 13mm guy got back to me (he was emailing my old email address)
He posted me some pics of the wheels, I am uploading them for you to see.
temeluchus
PostPosted: 15:59 - 10 May 2010    Post subject: Reply with quote
they look ok
https://ssl.delti.com/cgi-bin/rshop.pl?dsco=1110&m_s=1&Cookie=froogle&details=Ordern&typ=R-139928&ranzahl=4&nichtweiter=1
maxxis are reputable, 55 quid
PostPosted: 16:05 - 10 May 2010    Post subject: Reply with quote
That rear is a BT45 I think (decent enough tyres), but looks almost worn out.
Not sure what the front is, but have a vague feeling it is a radial. Radial front and crossply rear combination is illegal.
temeluchus
PostPosted: 16:10 - 10 May 2010    Post subject: Reply with quote
I think its a Macadam. If its a 50 its a Crossply, if its a 100 its raidal.
Mr White
PostPosted: 16:49 - 10 May 2010    Post subject: Reply with quote
Is it realy illegal? What is the danger?
What is the difference between these types of tyres?
Can you post some pictures to ilustrate?
PostPosted: 17:00 - 10 May 2010    Post subject: Reply with quote
Difference between radial and cross ply tyres is the direction of the internal construction of the tyre.
Best just point you at the radial tyre Wikipedia entry:-
https://en.wikipedia.org/wiki/Radial_tyre
There are also bias belted tyres that are somewhere between the 2.
You can have a radial rear with a radial, bias belted or cross ply front, a bias belted rear with a bias belted or cross ply front, and a cross ply front only with a cross ply front. This is because of the different way they respond to the road in use.
Think the same applies to cars but not sure (not that there are many cross ply car tyres available any more), and you can't mix different types on an axle.
Some bikes have been fitted with a cross ply front and radial rear as standard.
Mr White
PostPosted: 17:38 - 10 May 2010    Post subject: Reply with quote
So on the outside they look the same? - may have similiar patern ?
Why do you think that the front is radial ?
...(I) have a vague feeling it (front tyre) is a radial.
PostPosted: 17:57 - 10 May 2010    Post subject: Reply with quote
From the outside yes they can look the same. The tread pattern has little to do with whether it is cross ply or radial (more to do with styling), and nothing to stop a tyre maker using the same tread pattern on a radial and a cross ply tyre).
As to that tyre, just that tread pattern looks like one I have seen on larger bikes with radial tyres.
I am NOT certain, so check the make / model / rating of that tyre.
mad4it028
PostPosted: 18:58 - 10 May 2010    Post subject: Reply with quote
bt45 is raial tyre too so no problem most moden tyres are radial
you can tell by the size ie 120/70r17 would be a radial tyre "r" indicating radial
hth
Robby
Dirty Old Man
PostPosted: 19:15 - 10 May 2010    Post subject: Reply with quote
Even though DK motorycycles are scum, and DK motorcycles don't deserve the piss from my cat's failing kidneys, they have some cheap maxxis tyres on their website - https://www.dkmotorcycles.com/?product_section=road_bike§ion=shop&product_category=motorcycle_tyres_jis7a&mode=nav_grid
Looks like a front in your size is under £50. If you're really skint then fit it at home, I do for all of my tyres. Lots of washing up liquid is the key. I have also had radials fitted by the local car garage for a fiver a wheel (loose) before.
PostPosted: 19:49 - 10 May 2010    Post subject: Reply with quote
hth
The BT45 isn't a radial tyre. It is one of the better tyres aimed at bikes designed for cross plies.
PostPosted: 20:56 - 10 May 2010    Post subject: Reply with quote
hth
I'm pretty sure the 'r' indicates rear.
mad4it028
PostPosted: 21:42 - 10 May 2010    Post subject: Reply with quote
hth
lol then your pretty wrong r stands for radial
kick start you may well be right thinking about it as i was thinking back to the last bridgestone i had thinking 045 but they were 020
el_oso
find a better place that does tyres.
universal tyres did me a set of bt45's for £150 front and rear including balancing and fitting. took the wheels off and dropped them down there and done it on the spot in about 10minutes
tyre name conventions usually
170/60zr17
170 = width
60 = profile
z = speed rating
r = radial
17 = rim size
the bt-45 is not radial. it is bias
Duke 390
Car: Jeep Wrangler 4.0L
PostPosted: 22:02 - 10 May 2010    Post subject: Reply with quote
Depends where the R is. Some BT45 tyres are listed as the BT45R which I think is for the ones for the rear wheel. There are also R rated tyres (but pretty uncommon, top speed of 106mph).
Normally a radial it would be something like ZR for a Z speed rated radial tyre.
BT020 is a radial.
el_oso
PostPosted: 11:54 - 11 May 2010    Post subject: Reply with quote
forgot to mention that tyre manufacturers usually right and R for 'rear' next to the name of the tyre i.e. where it says bt-45R
Duke 390
PostPosted: 12:35 - 11 May 2010    Post subject: Reply with quote
Not on a BT45.
The last post was made 16 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 128.22 Kb
