CBR600F Difficulty changing gears
Noxious89123
PostPosted: 19:30 - 10 May 2010    Post subject: CBR600F Difficulty changing gears Reply with quote
So as per topic title, I'm finding it difficult to get my bike to hange gear properly. I've had problems before with getting a false neutral between 4th and 5th, but i only really does it when clutchless shifting. When it does this, it makes a rather horrible crunching sound too.
The problem I'm having now, is that when I'm going any faster than just crusing at a steady speed, it doesn't want to change up through the gears. 2nd gear, clutch in, throttle closed, firm deliberate movement on the lever all the way up, clutch out. Still in 2nd.
It's weird, through the lever it still feels as though it's snicked into the next gear, but when I let the clutch back out it hasn't gone into the selected gear. Does it mostly 2nd to 3rd, but also does it 3rd to 4th and I think maybe 4th to 5th aswell. No problems 5th to 6th or 1st to 2nd.
I did drop the bike (it's more like i just put it down on it's side tbh) onto the LH side about 3~4 weeks ago, and I've only ridden it a couple of times since then. It has bent the gear lever ever so slightly, but the movement of the lever and all the linkage is still smooth as it should be.
Chain tension seems to be ok, and oil was changed about 4k ago.
It's worse the higher up the revs I go. If I'm just pootling, it's ok.
I'm thinking it's going to be worn / bent selector forks, or worn dog gears? Sad
Bendy
Mrs Sensible
PostPosted: 19:39 - 10 May 2010    Post subject: Reply with quote
Get the oil changed, if it's been 4k since the last one it's due anyway.
Mine would do similar on occasion, usually on trackdays. Change of oil always sorted it out.
If it's still being an arse after an oil change, look at droppage-caused issues. But oil's the easiest to check.
Noxious89123
PostPosted: 20:00 - 10 May 2010    Post subject: Reply with quote
Oil change is every 8k iirc?
Worth a shot though, it was done before the winter, and has been sat for about 5 months.
Could try a new gear lever too.
PostPosted: 20:12 - 10 May 2010    Post subject: Reply with quote
Is your clutch properly adjusted?
I would have thought if the forks were bent/worn dogs it would go in, then jump straight out again.
jay12329
Dr. Evil
PostPosted: 20:13 - 10 May 2010    Post subject: Reply with quote
As per bendy my Hornet was the same. Oil change on those at least every 4k. If not less.
Service intervals should be 4k on that bike.
HTH
J
Bendy
Mrs Sensible
PostPosted: 20:14 - 10 May 2010    Post subject: Reply with quote
Pretty sure service intervals are 4k, oil change at each, other stuff spread out.
PostPosted: 20:21 - 10 May 2010    Post subject: Reply with quote
Oil's 4K, I think Oil & filter's 8k. Thumbs Up
L4Isoside
PostPosted: 20:28 - 10 May 2010    Post subject: Reply with quote
When accelerating hard and clutchless shifting i find mine sorta jumps outta gear, its nasty. I just stick with the clutch now, but nice to know if its fixable!
Noxious89123
PostPosted: 20:38 - 10 May 2010    Post subject: Reply with quote
Hmm.
Maybe I'm just being a penis.
EDIT:
No, oil is definitely every 8k, so says haynes and the original Honda manual. I will change the oil anyways, as it's the easiest thing to try first.
DrDonnyBrago
PostPosted: 21:46 - 10 May 2010    Post subject: Reply with quote
Noxious89123 wrote:
Hmm.
EDIT:
Oil and filter is 8k as you said, but it is wise to do it every 4k.
Checked the haynes before i read your post Mr. Green
gmanxiii
PostPosted: 10:39 - 11 May 2010    Post subject: Reply with quote
I had a similar problem on both my NC30 and CBR FX and it turned out that where the footpeg goes into the gear lever there wasn't enough grease. When you had your foot on the peg whilst riding change up it would stop the lever from returning down, so I couldn't change up again. Ended up having to give it a small tap to loosed it before being able to change gear. Might be worth having a look?
I kills hondas
VFR400NC30 > ZZR600 > CBR600FX > CBR1000rr
PostPosted: 11:09 - 11 May 2010    Post subject: Reply with quote
Make sure the clutch is adjusted properly and the gear shift linkage is correctly lubricated.
Walloper
PostPosted: 12:05 - 11 May 2010    Post subject: Reply with quote
I'd go for the clutch adjustment check 1st.
And maybe you are a penis after all.... Razz Karma
prawny1
PostPosted: 16:18 - 11 May 2010    Post subject: Reply with quote
check your chain tension my little 400 honda gets nuetral between 1 + 2 if I clutchless change with too much chain slack,
The gear linkage could probably do with a check over too, adjusting the linkage down a few mil might help give a more positive upshift
hellkat wrote:
Noxious89123
PostPosted: 19:50 - 11 May 2010    Post subject: Reply with quote
The linkage and lever are in good condition, and the movement is smooth, but I will take a look none the less. The lever is definitely returning properly.
Chain slack seems ok, but I'll make sure to check it accurately with a ruler rather than doing it by eye.
Cheers for the help guys, it's reassuring at the least Smile
The last post was made 16 years, 124 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 88.56 Kb
