| Noxious89123 |
 Noxious89123 World Chat Champion
 Posted: 19:30 - 10 May 2010 Post subject: CBR600F Difficulty changing gears |
So as per topic title, I'm finding it difficult to get my bike to hange gear properly. I've had problems before with getting a false neutral between 4th and 5th, but i only really does it when clutchless shifting. When it does this, it makes a rather horrible crunching sound too.
The problem I'm having now, is that when I'm going any faster than just crusing at a steady speed, it doesn't want to change up through the gears. 2nd gear, clutch in, throttle closed, firm deliberate movement on the lever all the way up, clutch out. Still in 2nd.
It's weird, through the lever it still feels as though it's snicked into the next gear, but when I let the clutch back out it hasn't gone into the selected gear. Does it mostly 2nd to 3rd, but also does it 3rd to 4th and I think maybe 4th to 5th aswell. No problems 5th to 6th or 1st to 2nd.
I did drop the bike (it's more like i just put it down on it's side tbh) onto the LH side about 3~4 weeks ago, and I've only ridden it a couple of times since then. It has bent the gear lever ever so slightly, but the movement of the lever and all the linkage is still smooth as it should be.
Chain tension seems to be ok, and oil was changed about 4k ago.
It's worse the higher up the revs I go. If I'm just pootling, it's ok.
I'm thinking it's going to be worn / bent selector forks, or worn dog gears?  ____________________
'06 Honda CBR125RW-6 ~ '00 Honda CBR600F-Y ~ '07 Honda CBR600RR-7 ~ Bikeless
'53 Ford Ka 1.3 ~ '03 Vauxhall Astra SRi 1.8 ~ '52 Vauxhall Astra SRi 2.2 ~ '53 Vauxhall Astra GSi |
| Bendy |
 Bendy Mrs Sensible
| Noxious89123 |
 Posted: 20:00 - 10 May 2010 Post subject: |
Oil change is every 8k iirc?
Worth a shot though, it was done before the winter, and has been sat for about 5 months.
Could try a new gear lever too. ____________________
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 20:12 - 10 May 2010 Post subject: |
Is your clutch properly adjusted?
I would have thought if the forks were bent/worn dogs it would go in, then jump straight out again. ____________________ My Flickr |
| jay12329 |
 jay12329 Dr. Evil
| Bendy |
 Bendy Mrs Sensible
| Wafer_Thin_Ham |
| L4Isoside |
 L4Isoside World Chat Champion
| Noxious89123 |
 Posted: 20:38 - 10 May 2010 Post subject: |
Hmm.
Maybe I'm just being a penis.
EDIT:
No, oil is definitely every 8k, so says haynes and the original Honda manual. I will change the oil anyways, as it's the easiest thing to try first. ____________________
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| gmanxiii |
 gmanxiii World Chat Champion
| MarJay |
 MarJay But it's British!
| Walloper |
 Walloper Super Spammer
 Posted: 12:05 - 11 May 2010 Post subject: |
I'd go for the clutch adjustment check 1st.
And maybe you are a penis after all....  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| prawny1 |
 prawny1 World Chat Champion
| Noxious89123 |
 Posted: 19:50 - 11 May 2010 Post subject: |
The linkage and lever are in good condition, and the movement is smooth, but I will take a look none the less. The lever is definitely returning properly.
Chain slack seems ok, but I'll make sure to check it accurately with a ruler rather than doing it by eye.
Cheers for the help guys, it's reassuring at the least  ____________________
The last post was made 16 years, 125 days ago. Instead of replying here, would creating a new thread be more useful? |
