honda cg problems
dave_manz
PostPosted: 15:26 - 10 May 2010    Post subject: honda cg problems Reply with quote
Ive got a 2002 honda cg 125, its kick start only and it runs fine but it wont start unless i use the choke.
anyone know why this is?
Ditto
PostPosted: 15:38 - 10 May 2010    Post subject: Reply with quote
Do you mean it just wont idle? Most carbed bikes are like this. Just keep the choke on for a minute or so till it idles without dying.
CG 125 > Bandit 600 > CBR 600 FY > Street Triple R
dave_manz
PostPosted: 21:09 - 10 May 2010    Post subject: Reply with quote
no it just wont start at all without choke.....and when its cold its very hard to start even with choke....thought it could be compression problem? i went to do the valve clearence and the engine was quite easy to turn over by hand
Walloper
PostPosted: 21:15 - 10 May 2010    Post subject: Reply with quote
Check the Spark Plug Colour and Air Gap. 0.8mm or 0.9mm.
If not plug related then maybe the mixture is too rich/weak.
Check the air cleaner is clean before you phanny about with mixture though.
To Start:
1) Choke on full.
2) Crack the throttle open 1/8".
3) Hoi the engine over on the kick-start. It should fire first kick.
4) keep the throttle open slightly for a few seconds then let release it and the engine should continue to run.
5) Switch the choke off after about a minute and the engine should run a a very low idle speed.
The last post was made 16 years, 139 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.28 - MySQL Queries: 13 - Page Size: 38.79 Kb
