Fibreglass alternative
Misc
PostPosted: 18:01 - 11 May 2010    Post subject: Fibreglass alternative Reply with quote
Evening,
On my rear fairing, a plastic bit has snapped off & it was used to connect the fairing to the bike. I've got 2 types of super glue but pretty sure it won't cope with the amount of vibrations & bumps of riding.
Any other household products i can use to secure it? I've got a heat gun & various crap lying about. So couldn't i melt the connector on somehow?
SlimRick
PostPosted: 18:04 - 11 May 2010    Post subject: Reply with quote
https://www.google.co.uk/search?hl=en&safe=off&tbo=p&tbs=vid:1&q=plastic+welding&aq=f&aqi=g10&aql=&oq=&gs_rfai=
Soldering iron and a couple of bits of scrap plastic, job's a goodun.
Misc
PostPosted: 18:07 - 11 May 2010    Post subject: Reply with quote
I actually have one too. Will give this a go. Thumbs Up
prawny1
PostPosted: 18:10 - 11 May 2010    Post subject: Reply with quote
Nice hot soldering iron to melt the parts back together and some plastic to use as filler material (thin slithers from discrete places work),
Then if you want to you can reenforce with epoxy resin, fibre glass etc,
Then if you want use sealing adhesive like siklaflex, tigerseal etc, rush/spread it on nice and thick on weak edges to help strengthen but keep flexability, using a heavy duty sealer over the repair helps to keep the bits in one piece if ever you drop the bike again too.
hellkat wrote:
Walloper
PostPosted: 18:33 - 11 May 2010    Post subject: Reply with quote
Ther eis stuff secific to repairing ABS (What all good bikes are made of) 'Plastex'. It's a white powder (Like Talc) and a clear liquid.
You wet the part you want to fix with the liquid then skoosh the white powder into it. It makes ABS I think and is as strong as the parent material.
It comes with a bit of plastic to use as a mould to replicate parts too.
about £30.
https://dirtbike.off-road.com/dirtbike/article/articleDetail.jsp?id=617418
Even better
https://www.amazon.co.uk/Plastic-Repair-Plastex-Standard-Kit/dp/B0013K4V10/ref=sr_1_1?ie=UTF8&s=kitchen&qid=1273599710&sr=8-1
SORTED! Thumbs Up
Halfrauds are selling a similar stuff too but not sure £££???.
The trouble with the solder iron approach is that you can easily overheat the material and it then becomes brittle.
Temperature control is a bit critical.
Glue won't make a molecular bond and it is only it's adhesive property that does all the work.
If it is a load bearing area then best use proper repair stuff.
Misc
PostPosted: 19:18 - 11 May 2010    Post subject: Reply with quote
Cheers guys. Really wanted to try & use stuff around the house rather then buying anything as it's only one connector. I'll give this soldering a go first.
virus
PostPosted: 19:55 - 11 May 2010    Post subject: Reply with quote
get a jam jar, put a teaspoon or 2 of acetone (nail varnish remover) in it, then drop a lego block (see colour coded this shit is) into the acetone.
when the lego block is melted, use the goop to make your repair and leave it to dry overnight in a warm place.
Job done. Thumbs Up
John
own: 81 xs1100g...
stirlinggaz
PostPosted: 20:18 - 11 May 2010    Post subject: Reply with quote
hi,
last time i bought plastech it was only a tenner!
& it lasts for ages, just like Q-bond (another great product) but is specifically for fairings.
had some really good results with it too.
cheers,
GAZ
Mr White
PostPosted: 19:54 - 13 May 2010    Post subject: Reply with quote
about £30.
Even better
SORTED! Thumbs Up
Halfrods charges £9 for small, £11 for bit bigger set
Assasination of the leadership of Poland, shots fired at survivers of the plane crash.
https://www.youtube.com/watch?v=FEx7HL4H5yk&feature=player_embedded WATCH IN 480P RESOLUTION TO SEE ALL THE DETAILS
tutton
PostPosted: 09:18 - 14 May 2010    Post subject: Reply with quote
I use a product called rapid rubber,
shit hot if you can get the fairing off the bike to do the work!
tried using that plastech on a nose fairing top edge and even tho it was layered right up real thick snapped within a week of normal riding
PostPosted: 09:44 - 14 May 2010    Post subject: Reply with quote
Epoxy resin?
tutton
PostPosted: 09:46 - 14 May 2010    Post subject: Reply with quote
Rapid rubber is a kind of epoxy glue yeah, but alot more flexible really, now i come to think of it i hate working with it as it takes days and days to get off hands!
The last post was made 16 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 87.98 Kb
