| Newbiker0507 |
 Newbiker0507 Crazy Courier
| temeluchus |
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| zombie_dave |
 zombie_dave Borekit Bruiser
| Mudskipper |
 Mudskipper World Chat Champion
 Posted: 13:00 - 12 May 2010 Post subject: |
| zombie_dave |
 Posted: 13:03 - 12 May 2010 Post subject: |
| temeluchus |
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
| Walloper |
 Walloper Super Spammer
| zombie_dave |
| stinkwheel |
 Posted: 13:57 - 12 May 2010 Post subject: |
Plastikote BBQ paint is the way forwards.
Covers like a dream. Lots of thin coats.
If you want to do it properly. Screw rubbing down, take the tank off, drain it, rinse it out with hot soapy water then nitromorse the whole tank.
This'll take it back to bare metal. Then apply a good primer and undercoat followed by your chosen finish, rubbing down between coats.
If you don't mind it looking ratty. The accepted technique is to spray rattle can paint on any old how. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Newbiker0507 |
 Posted: 16:18 - 12 May 2010 Post subject: |
| stinkwheel wrote: | Plastikote BBQ paint is the way forwards.
If you don't mind it looking ratty. The accepted technique is to spray rattle can paint on any old how. |
How do I deal with the plastic parts of my bike?
And which parts should I not paint?
https://img338.imageshack.us/img338/1295/photous.jpg
Uploaded with ImageShack.us |
| Kickstart |
 Kickstart The Oracle
 Posted: 16:22 - 12 May 2010 Post subject: |
Don't paint the shocks / forks without being careful to avoid getting paint on the sliding surfaces. Be careful with paint around the air intake.
As an aside, the bodywork looks pretty decent. Painting it matt black will destroy its resale value, and you would probably be far better off buying some cheap scratched 2nd hand plastics / tank and spraying them if you want it matt black. Can either sell the decent bodywork or just keep it to put back on when you sell the bike.
| N cee thirty |
 N cee thirty Banned
 Posted: 16:52 - 12 May 2010 Post subject: |
i think my cg looks pretty sickk in matt black
https://i825.photobucket.com/albums/zz176/robyarr/DSC00762.jpg ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
Jewlio Iglesias wrote: I actually did vote BNP once |
| Bambam3 |
 Bambam3 Renault 5 Driver
 Posted: 22:02 - 12 May 2010 Post subject: |
I noticed in another thread that somebody painted the engine cover.. shown below.
Is it safe to do so and what's the best method, as this would look pretty nice on my bike?
| That_Hornet |
 That_Hornet World Chat Champion
 Posted: 22:23 - 12 May 2010 Post subject: |
1) Sand 450 grit & 600 grit
2) Paint Primer Black, sand 600
3) Paint Primer Black, cheesecloth only
4) Paint Primer Black, cheesecloth only
5) Paint Semi-gloss, cheesecloth only
6) Paint Semi-gloss, cheesecloth only
Shamelessly stolen from here
Also been told by various people not to paint over the cooling fins on air cooled engines.  |
| G |
 G The Voice of Reason
 Posted: 23:09 - 12 May 2010 Post subject: |
When I sold my BMW, I found spraying more matt black was much easier/less hassle than cleaning etc - rust, dirt, chrome are all fair game . |
| stinkwheel |
 Posted: 00:56 - 13 May 2010 Post subject: |
| Waxaddict wrote: | I noticed in another thread that somebody painted the engine cover.. shown below.
Is it safe to do so and what's the best method, as this would look pretty nice on my bike? |
Take the covers off, carefully scrape off the old gasket, remove the filler cap and inspection covers.
Brush liberally with Nitromorse paint remover. Leave to stand for 10 minutes. Rinse off. Apply more nitromorse to any left over bits, re-rinse.
This'll leave you with clean, bare metal.
https://www.bikechatforums.com/files/covers.png
Rub down any corrosion with wire wool. Thoroughly wash in hot soapy water then rinse to degrease them. Mask off the threads for the filler cap and inspection covers.
I like to warm parts in the oven before painting (warm, not cook).
Apply lots of thin coats of plastikote BBQ paint, letting them almost dry between coats (about 5-10 minutes depending on temperature). Try to put too much on at once and it'll run.
Leave to dry for 24h. Remove any traces of overspray from the inside and gasket facings (those green plastic pot scrubbers are good for this) and refit using a new gasket.
Remember this is high temperature paint. It'll be soft until it's been heated up a couple of times or left to harden for a week or so. Be careful not to mark it the first couple of times out and try to avoid getting it splattered with dirt.
https://i48.photobucket.com/albums/f216/stinkwheel/cb500/DSCN0314.png
https://i48.photobucket.com/albums/f216/stinkwheel/cb500/DSCN0315.png ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| 505fatboy |
 505fatboy L Plate Warrior
| Bambam3 |
 Posted: 09:28 - 13 May 2010 Post subject: |
Cheers stinkwheel.  |
| Newbiker0507 |
| Robby |
 Robby Dirty Old Man
| Newbiker0507 |
| Newbiker0507 |
 Posted: 15:03 - 01 Jun 2010 Post subject: |
If you want to do it properly. Screw rubbing down, take the tank off, drain it, rinse it out with hot soapy water then nitromorse the whole tank.. |
Is this easy? |
| Kickstart |
The last post was made 16 years, 140 days ago. Instead of replying here, would creating a new thread be more useful? |
