Would an SM be the answer?
Whosthedaddy
PostPosted: 08:40 - 13 May 2010    Post subject: Would an SM be the answer? Reply with quote
I am getting sick and tired of the shoddy roads on the inner city London roads as part of my commute, this couple with just as bad tarmac at my end of the journey too. The vibrations and bouncing was enough to shake a back box off and then a month or so later break the metal support bracket too (even though empty).
Its a nightmare on the throttle, either belting it along to absorb as much as possible or plodding about and being bounced all over the place.
Grrrr.
Now, I did look at the KTM 690 and Ducati baby hypomotard, could a SM be of better use on the pole holed urban sprint?
Frost
PostPosted: 09:01 - 13 May 2010    Post subject: Reply with quote
Mate had a 660SMC, the bike managed to shake it's own side stand off on smooth roads Laughing
If i lived in central london i'd have a SM just for the ease of low speed riding, and visibility given due to the higher seating position etc.
PostPosted: 09:24 - 13 May 2010    Post subject: Reply with quote
I love my TDM for London work, comfy, tall and with real punchy power, it is also a big looking bike and has a big turning circle. It's not exactly a SM but it is of a similar type of bike.
Irezumi aka Reuben
Carrot Top
PostPosted: 11:57 - 13 May 2010    Post subject: Reply with quote
Leaning past van/lorry/4x4 mirrors can be a bit of a pain. I think the upright seating position gives you more confidence full stop. I probably go through London just as quick on a deauville as I do on my SM. The SM seems to wheelie alot more though!
Getting in to London on the major A-roads will be a pain though. According to G the new 690 is much better for vibrations but the older KTM's and most other SM's are generally rpetty annoying for them.
I think the ideal bike is probably a CB500/ER6 sort of thing. Or better still a Deauville, even with those panniers they get through almost every gap a scooter can.
Pictorgraphicalfantastical
boundy
PostPosted: 12:38 - 13 May 2010    Post subject: Reply with quote
I think you might be getting confused between supermotos and commutermotos
delvey91
PostPosted: 13:26 - 13 May 2010    Post subject: Reply with quote
SM is always the answer.......
2016 Honda Africa Twin
2006 KTM 200 EXC
PostPosted: 13:42 - 13 May 2010    Post subject: Re: Would an SM be the answer? Reply with quote
A trail style bike can have softer suspension and not still bottom out under harsh braking/cornering (and both together).
The softer suspension will help smooth out the bumps.
The longer travel shouldn't help, however much we complain about roads in the UK - none are THAT bad!.. however of course as above can mean softer suspension is more practical.
Oddly enough, a commutermoto may actually be better for smoothing out bumps because they tend to be a lot heavier - so there's more momentum and a better ratio of sprung to unsprung weight.
The 690 is the smoothest of the three decent lightweight big cc trail/supermoto bikes I rode.
Note the standard 690SM (not SMC) and Dukes weigh more than the enduro/SMC version. However, if I'm paying for a light weight 'sporty' bike, that's what I want to get Smile.
Welcome to have a go on my 690 sometime if you're over this way.
As I've gone on about before - if you do lots of tight filtering, you will probably find the SMs a bit limiting - there's enough cases where I'd take my GSXR between a gap, but physically wouldn't be able to fit the KTMs bars.
PostPosted: 14:08 - 13 May 2010    Post subject: Re: Would an SM be the answer? Reply with quote
I find this but rarely, as i've said before I find the sterring lock more of a problem than the wideness of the bars. There are plenty of other reason why my TDM is better than you GSXR for commuting but we will not go into that now Wink
I have found it is fairly easy to wiggle through gaps smaller than the bike with a mixture of leaning and counter steering.
PostPosted: 14:14 - 13 May 2010    Post subject: Re: Would an SM be the answer? Reply with quote
I don't see how you can go down between two vehicles where width is physically smaller than the bars or very, very close at least.
Going through a single gap is much less of an issue as you can usually get one side of the bars through before the other or similar.
Turning can much more easily be mitigated with planning and a tyre that wasn’t expensive on the rear where the former fails Smile.
As I’ve said, don’t think the KTM is any better than the GSXR turning circle wise; may even be worse. A bit of a nightmare on singletrack trails.
PostPosted: 14:28 - 13 May 2010    Post subject: Re: Would an SM be the answer? Reply with quote
Because as you turn the bars and lean the width of them (in relation to the 2 cars) changes.
I'm going to try to describe it but probably fail.
Clearing the left mirror first come into it with the bike more toward the right then push out the left bar and lean left. Now the bike is tilted left with the left bar out and the actual width of the bike is smaller as soon as you have cleared the left mirror push the right bar forward which puts the bike upright and should clear the right mirror in the process, you can do this at walking pace or as I have done at 10-15mph.
I don't think I have explained it well but it makes sence in my head, nb I only do this with stationary traffic.
PostPosted: 14:35 - 13 May 2010    Post subject: Re: Would an SM be the answer? Reply with quote
I quite get the clearing mirrors thing – I still have to do this on occasion on the GSXR, especially if I’ve left my own mirrors out.
If it’s just the mirrors that are two narrow – single point to get through – it’s not a big issue. It’s when the gap between the body of the vehicles is too tight all along that I find the smaller bike better. Folding the mirrors of the GSXR in means I can get through gaps that the KTM wouldn’t fit through or at least would be damn tight.
A while ago I had a case on the zx9 where the right hand muff was against the side of a van while the left hand bar was pretty close to a car on the other side. No way I’d have had a chance on a bike with wider bars.
This decreased width also gives a bit more confidence filtering towards oncoming traffic.
PostPosted: 14:51 - 13 May 2010    Post subject: Re: Would an SM be the answer? Reply with quote
With the TDM I don't have to fold the mirrors as the bars are the widest part.
On coming traffic is easy the other cars will see you and move.
I'd be interested to know the actual difference between your GSXR and my TDM in width I don't think it would be a great deal 4" maybe 6" how many gaps between cars will be in that 4-6" gap that you can get through and I can't.
Often if I come to a gap I can't get through I can turn 90 degrees and find a different route, swings and roundabouts I guess.
I dislike commuting on my Speed Four because of the shitty turning circle, I also like the punch of the TDM, the instant kick of power.
Whosthedaddy
PostPosted: 14:51 - 13 May 2010    Post subject: Reply with quote
When I sat on the SM's it didn't feel natural nor did it feel bad. The idea of having nothing between your legs (big fuel tank) was a little worrying and the wind blast would be tiresome. However, averaging a fair bit over the NSL for the 15 -20 miles before the remaining 15 odd miles of 30/40mph starts, I'm lucky to have a clean licence still.
Mines the TRX so TDM but smaller and more sporty. A TDM was parked next to me a while back and quite a bit bigger really!
What the hell is a commuter moto when its at home?
Other option maybe is an enduro, but being even taller and wider maybe not even worth thinking about.
Maybe there is something to the likes of a pan or big comfy Beemer?
PostPosted: 14:54 - 13 May 2010    Post subject: Reply with quote
I feel the TDM is still a fairly narrow bike, (for something with bars) the main benefit from the TDM is more visablity, more comfortable and a better turning circle.
PostPosted: 15:10 - 13 May 2010    Post subject: Re: Would an SM be the answer? Reply with quote
Enduro bikes tend to use the same bars as supermoto bikes.
A commutermoto style but with low power and lots of weight generally – for instance I believe the XT660 range has around the weight of my GSXR, but only 2/3rs the power of my 690, which weighs a decent chunk less and has better components.
I do fairly often find myself filtering on the GSXR in situations I wouldn’t on the KTM. Until having ridden the KTM and ZX9 etc back to back, I wouldn’t have said sports bike either. In such situations, there isn’t another way generally – the traffic is tight for a reason and I’ve chosen the route that offers the most width. I’m not going to expect on coming traffic to get out of my way when there’s a double decker bus very close to the other side of it! Smile
The narrowness easily makes up for the need for a little planning (or wheel spinning) for me.
Oh and it’s definitely got ‘punchy power’ when it’s needed Smile.
Whosthedaddy
PostPosted: 15:40 - 13 May 2010    Post subject: Reply with quote
Commuting in Lonon has turned me from mild mannered to racing and beating couriers through the traffic and shouting at cars on the way.
I find that even though 'bigger' than the peds, I can actually filter just as fast as them and often beating them when they've gone on the other side of the road and I've stuck to down the middle of the cars.
Clip ons do seem like a good idea, nice and narrow, low and easily directions easily changed.
A sports bike on the roads just doesn't?
The last post was made 16 years, 125 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 100.03 Kb
