What is coverd on a motorcycle service?
Grendel
PostPosted: 16:29 - 13 May 2010    Post subject: What is coverd on a motorcycle service? Reply with quote
I was wandering what else is covered on a motorcycle service since I already changed the oil/oil filter and put a K&N filter on the bike last year but wasn’t brave enough to take it apart to change the plugs.
So I was wandering what else I should be checking or would be checked if I booked it into a garage for a service?
Past bike: 2004 Hyosung Comet
Current bike: 1993 Honda Transalp
Transalp Page: https://www.facebook.com/home.php?ref=home#!/group.php?gid=11418462079
Pickledswede
PostPosted: 16:31 - 13 May 2010    Post subject: Reply with quote
Look in the front of your Haynes manual, different things are required at different mileages. For example on most bikes after 16k valve clearances have to be checked. That's the biggy
Grendel
PostPosted: 16:37 - 13 May 2010    Post subject: Reply with quote
That sounds expensive
Pickledswede
PostPosted: 16:40 - 13 May 2010    Post subject: Reply with quote
Depends on the bike, it can be done yourself, it's the time that it takes to do that's expensive because it means taking so much apart, I think.
Paxovasa
PostPosted: 16:48 - 13 May 2010    Post subject: Reply with quote
My 16000 mile service for the bandit cost £180 (that was back in 2007). It is getting due for the 30000 service( I reckon that will cost £250).
When I service my bike it gets oil, oil filter, plugs, (check air filter/replace) clean and check brakes, I do the above every 5000/6000 miles Thumbs Up
deanoet
PostPosted: 16:55 - 13 May 2010    Post subject: Reply with quote
Yup, the valves are a 5 minute check
Unfortunately (on the hormet at least) they are at the bottom of the engine, so it needs practically taking apart to get to them
Random list of other stuff is:
Lube / oil moving parts and cables
Plugs like you mentioned
Fluid change (coolant, brake fluid, clutch fluid, forks etc etc)
New Cables / pipes (Clutch, throttle, brake lines etc etc)
Brake Pads
Like was said they will have set periods that they should be replaced, but as part of the Pre Ride checks you should be checking most things for wear anyway. Especially brake lines and brake pads
Most of it is easy to do yourself, just make sure you have the correct tools before you start. Depending where the plugs are get the correct tool, as if like on the hornet 2 will be nearly under the frame, so very hard to get to with standard plug removal tools. Smile
Walloper
PostPosted: 17:49 - 13 May 2010    Post subject: Reply with quote
RTFB
All bikes are different.
My current ride list a load of shite that is computer based so no way I can check it.
But Oil, filter, brake pads/shoes, tyres, suspension....... etc etc etc....
Noxious89123
PostPosted: 17:53 - 13 May 2010    Post subject: Reply with quote
Balance your carbs! Makes a nice difference Cool
Er, no they're not. Laughing How the hell would that work?!
Danny
Ask Me About Stoppie School
PostPosted: 19:01 - 13 May 2010    Post subject: Reply with quote
Your bike owners manual might say what needs to be done when, if not get a Haynes manual for it.
Other thing you could try is calling up your bike manufacturers local dealership and asking them to e-mail over a list of what they'll do in a service for your bike. Sometimes this is available on their website.
Clanger
Stirrer
PostPosted: 21:19 - 14 May 2010    Post subject: Reply with quote
Grendel, why don't you ask Dan to do a service for you (from Thornhill)...he has always done my car and bike servicing, will even get the parts cheap from his contacts at Halfrauds. Thumbs Up
hellkat
PostPosted: 21:43 - 14 May 2010    Post subject: Reply with quote
Do you guys really do that, like really often?
Pre-ride checks?
I think I read about that once in a Haynes manual.
hellkat
maintenance: dude, wait, what? Confused
Grendel
PostPosted: 23:40 - 14 May 2010    Post subject: Reply with quote
I dont know who Dan is?
But i am looking for somewhere trusted and sympathetic to old bikes to get it serviced since may as well get it done properly if the tank is coming off for new plugs.
Grendel
PostPosted: 09:43 - 15 May 2010    Post subject: Reply with quote
lmfao.
its a 5 minute check on a single cyl. 4 stroke with no fairings.
anything else and it takes a bit longer than that.
btw, are you from australia? i heard everything there was upside down.
I guess it will take a while to get to them on my old transalp then Laughing
The last post was made 16 years, 147 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 80.85 Kb
