| BelleBot |
 BelleBot Nova Slayer
| everyreasonto |
 everyreasonto Nitrous Nuisance
 Posted: 23:01 - 12 May 2010 Post subject: |
| Mudskipper |
 Mudskipper World Chat Champion
 Posted: 23:03 - 12 May 2010 Post subject: |
Is it a chewed-up phillips head? You could try hammering a torx bit into it (I got a £1.50 set from a hardware shop) and see if that will turn it. I've done that with mashed-up master cylinder bolts before.
I would also spray lots of loctite freeze & release all over it first.  ____________________ CBR125|||GSXR400|||CBR400|||CBR400|||CB250RS|||GSXR750|||CB250RS
"You're clumsy, you eat too much and you behave like a 12 year old boy. But you know what? Every once in a while, you find a thumb." |
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
 Posted: 23:24 - 12 May 2010 Post subject: |
You could try a nut splitter if you can get one in it to crack the nut off:
https://www.mptools.co.uk/products.asp?partno=PC70
If that doesnt work then a proper penetrating oil such as plus gas might work better than lubricants such as WD40, 3 in 1 etc. As it happens though brute force, heat/cold and big hammers normally are what is called for.
Could you cut off/drill out one of the heads to release it?
If worse happens then it'll probably require drilling out to remove the bolt without damaging the surrounding material. If you did damage the surrounding area then and helicoiling or oversize tapping would be required. I am not too sure what the bolt in question looks like though so can't offer exact advice.
Good luck, rust is a c***ing f*** bag of a b****** to work with . |
| trisers |
 trisers Scooby Slapper
| temeluchus |
| Frost |
 Frost World Chat Champion
| Walloper |
 Walloper Super Spammer
| BelleBot |
| Darth |
 Darth World Chat Champion
| el_oso |
 el_oso World Chat Champion
| chris-red |
 Posted: 14:13 - 13 May 2010 Post subject: |
Assuming the bolt hasn't rounded but the nut has
Get one of these
https://www.rpcpromo.com.au/images/superWrench16_photo.jpg
It will grip anything put it on the nut and get a socket on the bolt, this will not let the nut slip even if it is a perfect circle, the more force you put through it the tighter it grips. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| Mudskipper |
| chris-red |
| el_oso |
| nightshaddow |
 nightshaddow Nearly there...
 Posted: 19:43 - 13 May 2010 Post subject: |
had one similar not long ago,what i did was brutal but worked,
angle grinder with a 1mm cutting disk cut the nut away and tap the rest with a hammer job done
didnt worry about the electrics in the bolt as new ones in new indicator ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
Current rides CB 125 TDE(the next project) NS125RK ( now on the road ) CB125TDC (soon to be project 17) melody ( the nephews ) |
| chris-red |
| el_oso |
| lydanial |
 lydanial Brolly Dolly
| Pete. |
 Pete. Super Spammer
| Billing |
 Billing World Chat Champion
| el_oso |
| chris-red |
 Posted: 12:45 - 14 May 2010 Post subject: |
Did you read the thread? it is the remants of an indicator going through plastic (I assume) a mudguard. If the plastic is threaded I will eat my arse. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| chris-red |
| DrDonnyBrago |
 Posted: 12:57 - 14 May 2010 Post subject: |
The last post was made 16 years, 121 days ago. Instead of replying here, would creating a new thread be more useful? |
