BIKE IDLES AND CUTS OUT WHEN GIVEN THROTTLE
btb.v
PostPosted: 18:25 - 13 May 2010    Post subject: BIKE IDLES AND CUTS OUT WHEN GIVEN THROTTLE Reply with quote
Hi new to this so forgive me if in wrong thread etc, I have a Kymco Zing 125 2001, i replaced the gear switch on the bike, got the bike running but now it cuts out, when warm and given throttle, the bike idles ok, just when given throttle it splutters and dies on me any suggestions?
Paxovasa
PostPosted: 18:33 - 13 May 2010    Post subject: Reply with quote
Choke stuck on, possible air breather blockage.
btb.v
PostPosted: 18:40 - 13 May 2010    Post subject: Reply with quote
Im quite a novice at bikes, is this quite and easy fix?
Grimnir
PostPosted: 18:41 - 13 May 2010    Post subject: Reply with quote
Water in the carb? Shouldn't be too hard to fix on a 125. It was a bit harder on my zx6 - 4 carbs well hidden by the frame. Ask if you want to know how to do this (if water is the problem). Do you keep it in a garage / under a cover / exposed to all that nature can throw at it? Has it rained your way recently / have you jet washed it?
btb.v
PostPosted: 18:52 - 13 May 2010    Post subject: Reply with quote
Hi no it was in a garage with the tank off etc, as when i bought it, there was a light problem, which we narrowed to the r/h gear switch, so after the tank was put back on, and gear switch was fine, i started having the problem with it cutting out when given throttle......... blooming bike doing my head in Very Happy
Grimnir
PostPosted: 19:20 - 13 May 2010    Post subject: Reply with quote
Ok, not water then. Following from what Paxovasa said, my other thought would be blocked / trapped fuel line. Apart from that, I'm out of ideas, sorry
Paxovasa
PostPosted: 19:35 - 13 May 2010    Post subject: Reply with quote
Does it have an inline filter?
Check fuel is getting to the carbs.
Does the tank get pressurised (when you undo the petrol cap does it suck in air).
The last post was made 16 years, 141 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.67 - MySQL Queries: 13 - Page Size: 50.7 Kb
