Brake constantly applied
gui montag
PostPosted: 17:44 - 14 May 2010    Post subject: Brake constantly applied Reply with quote
Hi,
My front brake is constantly applied, making a slight screeching sound. I just bought the bike and the seller told me it's because the brake pads are brand new (which they are) and that it will go away. But I've ridden the bike 40 miles since then and there's no improvement.
Should I just wait some more and do some hard braking or is it a sign that there's something wrong with the calliper?
All help is appreciated.
Paxovasa
PostPosted: 17:49 - 14 May 2010    Post subject: Reply with quote
Are the brakes binding badly?
You may need to clean the pistons if the seller just put the new pads in without giving them a clean.
Tom_B1H
PostPosted: 17:50 - 14 May 2010    Post subject: Reply with quote
Most probaly the piston(s) not retracting
Previous: '08 Suzuki DRZ400SM > '04 Kawasaki ZX-6R B1H
Current: '07 Kawasaki ZX-6R P7F
Bambam3
My front brake rubs a little when I push the bike, a bit of resistance, but I was told this was normal with all bikes/disc brakes. ?
serlant
PostPosted: 17:54 - 14 May 2010    Post subject: Reply with quote
my front brakes make a sort of scratching noise if i lift the front wheel off the ground and spin it, still gets 4 or 5 rotations before it stops, brake disc is only warm to the touch and still stops well, does it do it while you ride? how loud is it?
Paxovasa
PostPosted: 17:56 - 14 May 2010    Post subject: Reply with quote
I suggest you take the caliper off, remove the pads, move the pistons out and give them a clean (brake cleaner or WD40) dont get WD40 on the discs or pads.
Push the pistons back in and replace pads (if pads are shiney then give then a gentle rub on a paving flag to get the shine off) then reattach the caliper(s).
chillyman0
PostPosted: 17:58 - 14 May 2010    Post subject: Reply with quote
gonna need to get them apart and clean the surfaces of the piston(s)
gui montag
PostPosted: 18:05 - 14 May 2010    Post subject: Reply with quote
Allright, but the bike only has about 700 miles on it, can the pistons really need cleaning? The bike has been stationary in a garage at the police since march '08, could something have dried up or similar?
Paxovasa
PostPosted: 18:07 - 14 May 2010    Post subject: Reply with quote
More reason to clean the pistons if the bike has been stood for that long. I would also change the brake fluid (if it has not already been done) Thumbs Up
Kal
There is your problem right there, it was stood far too long. I have the same thing happening on the trike. Listen to Pax on this one, his advise is spot on.
Kal...
gui montag
PostPosted: 18:10 - 14 May 2010    Post subject: Reply with quote
OK, Thanks! Smile (And sorry for putting this thread in the wrong section)
Frost
PostPosted: 18:46 - 14 May 2010    Post subject: Reply with quote
Check the caliper and make sure you can see a little bit of the pistons poking out. If you can't that might suggest the pads are the wrong ones.
Old Git Racing
PostPosted: 20:07 - 15 May 2010    Post subject: Reply with quote
loosen calipers (not too much) apply brakes, retighten calipers.
OGR
The last post was made 16 years, 119 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 72.99 Kb
