Bandit Head race bearings
That_Hornet
PostPosted: 19:50 - 14 May 2010    Post subject: Bandit Head race bearings Reply with quote
I can't get them to fit correctly.
I believe their sat right, have the bottom on and the top sat in, When i stick the sanction through and put the dust cap on i can get the locking tab/bolt thing on. Its almost like their too long.
I've got tapered roller bearings from the bike shop made by koyo or someone. instead of the ball bearing i took out.
Anyone had a similar problem and any tips. I need to get it back on its wheels. Its taking up the center of the garage. Sad
Thanks
Jack Karma
Noxious89123
PostPosted: 20:46 - 14 May 2010    Post subject: Reply with quote
What did you use to drive them in? Are you sure they're all the way in? Sounds like you have only got them part way in.
That_Hornet
PostPosted: 20:50 - 14 May 2010    Post subject: Reply with quote
The lower bearing go hit down with a hammer and the old bearing inner race, The lower outer race got hit into the frame with a copper hammer. The top race got hit in with a piece of exhaust pipe that fitted on the outer race and driven down.
Why is it when you want to do something quickly it take for ever. Rolling Eyes
el_oso
PostPosted: 20:58 - 14 May 2010    Post subject: Reply with quote
murphy's law
Duke 390
Car: Jeep Wrangler 4.0L
Noxious89123
PostPosted: 21:40 - 14 May 2010    Post subject: Reply with quote
When I did mine, I just tightened the adjuster massively to draw the bearings fully into place, then loosened it back off to the correct adjustment. Worked very well Smile
That_Hornet
PostPosted: 22:24 - 14 May 2010    Post subject: Reply with quote
Yea, i've been reading up on it, ill try and get hold of some threaded bolt and a big washer and nut and tighten it up.
Ill let you know how i get on. Thumbs Up Karma
The last post was made 16 years, 147 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 49.37 Kb
