Wheel bearings
JacPowell
PostPosted: 22:38 - 14 May 2010    Post subject: Wheel bearings Reply with quote
Anybody got any tips on how to remove wheel bearings ? Dont want too be paying through the roof for a tool thats going to be used twice in its life,
Thanks,
Jac
That_Hornet
PostPosted: 22:41 - 14 May 2010    Post subject: Reply with quote
Bit of drift. I use a old weight bar that i cut up. Seen hammer handles, brooms etc. Just to knock it out.
PostPosted: 22:41 - 14 May 2010    Post subject: Re: Wheel bearings Reply with quote
Thanks,
Jac
Blind bearing puller does well, and I find that when I buy a tool I use it more than I ever thought I would because I know I've got it.
Another alternative is to use a screwdriver poked through the wheel onto the edge of the bearing but it is very easy to damage the wheel that way.
JacPowell
PostPosted: 22:44 - 14 May 2010    Post subject: Reply with quote
Cheers for replies just had a look at the blind bearing pullers and there not too expensive actually.
You know your probably right actually no doubt if i did get one someone would want too borrow it next week so i might aswell.
All the Best,
Jac
DrDonnyBrago
PostPosted: 23:04 - 14 May 2010    Post subject: Re: Wheel bearings Reply with quote
That is very true, every time I buy a tool and think I wont use it much I find a thousand things it helps with. Best example has been my dremel, one of my best buys so far and I only bought it to make a neat cut on a bike fender.
MaybeGuy
PostPosted: 00:18 - 15 May 2010    Post subject: Reply with quote
lol ''proper tools''
Phoenix
Twisted Firestarter
PostPosted: 01:48 - 15 May 2010    Post subject: Reply with quote
I usually just use the rear wheel spindle for the rear wheel bearings. The sleeve in the middle of the wheel can be knocked aside then just get the end of the spindle flat on the bearing and give it quick taps with a hammer. Front wheel you can use anything strong and flat lying around as the wheel centre is so narrow, a 1/2" socket extender bar is good.
hondapartsman
PostPosted: 08:09 - 15 May 2010    Post subject: Reply with quote
I use a piece of rod, never had a problem, just make sure there's no bearing retainer. Not many bikes use those but I've know of people not look and bang away for ages, it there is a bearing retainer then getting that out without breaking it is a whole other issue.
In the end all comes back to the beginning
Quote Me Happy
PostPosted: 08:14 - 15 May 2010    Post subject: Reply with quote
I use a nice length of metal rod with a nice edge to it. Heat the hub as well to help them drop out and freeze the new bearings before putting them in.
PostPosted: 08:41 - 15 May 2010    Post subject: Re: Wheel bearings Reply with quote
I have a blind bearing puller but don't use it most of the time.
An appropriate drift, ideally with a slight lip. Once you've got it to move slightly, you can usually get the middle spacer tube to move over enough that it doesn't take long for the rest.
The last post was made 16 years, 147 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 64.24 Kb
