front brake clicks when applied...
chillyman0
PostPosted: 16:20 - 16 May 2010    Post subject: front brake clicks when applied... Reply with quote
when you first apply the brakes very lightly you hear a click or crack sound and it will sometimes happen when you ease off the brakes or turn under braking. First i thought it was head bearings gone but on closer inspection the sound is coming from somewhere lower. The only thing i can think is that the pads are looser than normal and they move about but that wouldnt explain it happening when turning or easing off the brakes Question any ideas? its a vfr750 with braided lines btw
That_Hornet
PostPosted: 16:28 - 16 May 2010    Post subject: Reply with quote
Have the vfr got floating disks?
Hornets click under heavy braking.
chillyman0
PostPosted: 16:35 - 16 May 2010    Post subject: Reply with quote
yeah they are but its under the lightest of braking Confused
That_Hornet
PostPosted: 16:39 - 16 May 2010    Post subject: Reply with quote
Check your calipers, When the wheels turning are they slightly out of place and snapping back when its pads are biting the disk?
chillyman0
PostPosted: 16:52 - 16 May 2010    Post subject: Reply with quote
yeah thats what i was saying in the original post but that would explain as the pads bit the discs but i can work out why it would do it as you turn under braking and as you ease off Shocked Question
The last post was made 16 years, 167 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 42.62 Kb
