Is it possible to make a dirt/pit bike road legal ?
Gazz
PostPosted: 20:11 - 16 May 2010    Post subject: Is it possible to make a dirt/pit bike road legal ? Reply with quote
I have been giving this some thought and was wondering if this was possible or not ?
Idea
I know you can build a kit car from scratch (with doner car parts, etc) and get it registered and put on the road, but would it be possible to do with a bike ?
Thinking
After searching the internet, I have came across some mixed opinions, but thought I'd ask on here first, because this is Bike Chat Forums after all.
Rolling Eyes
If it is possible, would would need to be done on it ?
Lights, controls, what else Question
My internet search found these replies, both are conflicting answers:
Thumbs Down ----- NOT POSSIBLE ------ Thumbs Down
" Assuming you live in Britain, you can't.
There is no way to get a pit bike through an M.S.V.A. test. Without passing an M.S.V.A. test, you can't get it registered. Therefore, you can't make it road legal.
End of.
Thumbs Up ------- IS POSSIBLE ------- Thumbs Up
"I can't imagine it will present too many issues buying one of the ones off ebay.
You could always simply make your supermot pitbike road legal, shouldn't be too hard, you can buy the kits to make it road legal, horn lights, indicator etc. do a search, then you have to pass a test, like a super MOT to prove it's road legal, you may have to change the tyres etc. to road legal ones. the same rules apply to all bikes
Cheers in advance.
Very Happy
PostPosted: 20:17 - 16 May 2010    Post subject: Re: Is it possible to make a dirt/pit bike road legal ? Reply with quote
Yes it is. Have a search in the off road sections and there's various details about how to do it.
There's special allowances for dirt bikes which have a certain ground clearance too - too allow you too fairly easily register competition bikes that may be used on the roads to get between stages etc.
Quote Me Happy
PostPosted: 20:24 - 16 May 2010    Post subject: Reply with quote
Registering the bike
MOT
tutton
PostPosted: 20:25 - 16 May 2010    Post subject: Reply with quote
Possible yes,
Worth the cost of it? No, not really Laughing
PostPosted: 20:41 - 16 May 2010    Post subject: Reply with quote
Yes, didn't Binge do it?
Lambo
PostPosted: 17:11 - 25 May 2010    Post subject: Reply with quote
Tyres, Lights, Indicators, Plates, DVLA registration, And I think That Might Be It with an mot. dont know what the insurance company will say lol.
Mega idea. Good Luck
Dan
https://www.offroadobsessions.co.uk
c_dug
PostPosted: 18:53 - 25 May 2010    Post subject: Reply with quote
Out of interest can you do the same with a go-kart?
c_dug
andyscooter
PostPosted: 08:04 - 26 May 2010    Post subject: Reply with quote
go card would need mudguards over the wheels and probebly be a bit bigger
Paulington
PostPosted: 08:12 - 26 May 2010    Post subject: Reply with quote
c_dug
What Andy said, would need lights, mudguards etc.
Wouldn't be worth it unless you used a superkart.
PostPosted: 10:36 - 26 May 2010    Post subject: Reply with quote
Suspect a kart would be classified as a car and need to get through the car SVA rules. Which would probably be virtually impossible (especially if you had to get it through the emissions requirements for a modern car).
djr
PostPosted: 08:28 - 20 Aug 2010    Post subject: Reply with quote
Dan
Indicators are not required (which is why no dirt bike's require them) I also believe you can get away with a daytime mot and the only light you'll require is a brake light.
Ariel Badger
PostPosted: 08:41 - 20 Aug 2010    Post subject: Reply with quote
No brake light required for daytime MOT, This surprised me when I took a bike in with a rigged LED brake light and the MOT man told me it was not needed.
PostPosted: 10:01 - 20 Aug 2010    Post subject: Reply with quote
Indicators are compulsory unless the bike is exempt for one of the following reasons
A vehicle having a maximum speed not exceeding 25 mph;
A vehicle first used before 1st April 1986;
A vehicle which is constructed or adapted primarily for use off roads (whether by reason of its tyres, suspension, ground clearance or otherwise) and which can carry only one person or which, in the case of a motor bicycle combination, can carry only the rider and one passenger in the sidecar.
The other exception would be having no rear position lamp (the lighting regulations contain an exception that they do not apply to any vehicle not fitted with a rear position lamp, although they also list the rear position lamp as being compulsory with no exceptions).
Damon
PostPosted: 18:58 - 20 Aug 2010    Post subject: Reply with quote
Does that mean I do not have to worry about not having indicators on my road legal track bike?
PostPosted: 19:00 - 20 Aug 2010    Post subject: Reply with quote
Only if you can get away with the daytime MOT thing. Don't think your track bike would count of designed for use off roads.
rexy
PostPosted: 19:09 - 20 Aug 2010    Post subject: Reply with quote
Ive seen a couple of lads around here with plated up pit bikes, there tiny little 125 things, also seen a bloke on one up near rivvington looked full of trick bits again with a reg plate.
They have actually made a road legal gokart... well I belive so. i'e never seen on onroad, have a quick ebay search for it. Its bad enough in a super 7 on roads up here, so god knows how a gokart would handle on anything other than smooooth roads lol.
https://cgi.ebay.co.uk/2010-Plate-Road-Legal-Go-kart-170cc-/330462276662?pt=UK_Motorcycles
Damon
PostPosted: 19:11 - 20 Aug 2010    Post subject: Reply with quote
OK thanks have some Karma, Can you also clarify about the legalities of not having a brake light? I have bolted it on as I thought it was needed but would get rid of it in an instant if not needed.
Thanks Keith Thumbs Up
PostPosted: 19:36 - 20 Aug 2010    Post subject: Reply with quote
Daytime MOT requires reading the lighting regulations in a certain way (and I suspect means ignoring some older laws which it updates but which are not easily found).
The lighting regulations specify all the compulsory lights, most of which are compulsory if you have a rear position lamp (ie tail light). A brake light isn't compulsory without a rear position lamp (although it is one light I really would rather make sure I had), but the problem comes if your rear brake lamp is also a rear position lamp. Even if it has the facility for a rear position lamp but not wired up it could be argued that it is a non working rear position lamp hence all the rest of the lights become compulsory. However a brake light on its own should be a rear position lamp so should be OK to have without making the other lights compulsory.
Lighting regulations are here
Compulsory lights are here (table II for bikes)
Exemption from the rules for having no front or rear position light is here
Reading those if you have a front or rear position lamp then the exemption from those rules doesn't apply any more so all the other lights become compulsory.
MOT rules may be applied differently. MOT manual states:-
Machines first used before 1 April
1986 must have a stop lamp that
operates from at least one brake control.
Machines first used on or after 1 April
operates from both brake controls.
Which is a bit contradictory.
Damon
PostPosted: 19:41 - 20 Aug 2010    Post subject: Reply with quote
Many thanks for the above info Thumbs Up
PostPosted: 21:40 - 20 Aug 2010    Post subject: Reply with quote
In my experience it does vary massively between MOT testers.
I've recently got a c90 passed as a 'day time MOT' - though it was an off-road race bike, the trials tyres and lack of front mudguard were the only indication of this and it probably doesn't come under the normal classifications Smile.
The last post was made 16 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 114.28 Kb
