cr 85 no spark
dobby
PostPosted: 10:53 - 17 May 2010    Post subject: cr 85 no spark Reply with quote
i have recently replaced the engine in my cr85 but it has no spark...
so i was wondering what the proble could be and how i go about solving it,
as it doesnt have a stator jus a pick up and ignitor
would i check for an AC voltage when kicking it over at the coil to tell me the ignitor is dead if no voltage is present or a fault with kill switch or if i do get a voltage this would tell me coil is dead...
prawny1
PostPosted: 12:22 - 17 May 2010    Post subject: Reply with quote
Did you fit the electrics from your old engine?
If not do you still have access to them?
Even motocrossers should have a coil behind the flywheel to supply voltage to the low tension side of the ignition system, so if your aying you have no stator coil that is most likely your problem.
hellkat wrote:
dobby
PostPosted: 13:31 - 17 May 2010    Post subject: Reply with quote
yes i fitted all of the old electrics to it it has the coil behind the magnetic flywheel and the pick up... just was wondering if the way i described is the correct way to check each component
prawny1
PostPosted: 20:51 - 17 May 2010    Post subject: Reply with quote
I would check the a.c output of the stator first as you may just have a bad earth on the stator plate, the kill switch would be my next suspect.
If the bike ran before the engine swap it is probably just a wire on wrong or bad connection somewhere.
dobby
PostPosted: 08:38 - 18 May 2010    Post subject: Reply with quote
yes the bike ran fine before i seized it n killed the old engine, will check for dodgey earth point on it and try and by pass the kill switch
The last post was made 16 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 42.99 Kb
