Seeing MOTs Online
Ingah
PostPosted: 23:15 - 17 May 2010    Post subject: Seeing MOTs Online Reply with quote
Quick question regarding "failed" MOTs in the context of looking to buy a bike that has recently failed its MOT on a short list of minor items.
Is it possible to see exactly what the list of advisories were and also what the bike failed on (i.e. the whole MOT report) on the site that displays MOTs online (i'm aware i'd probably need the number on the V5 or whatever, but assuming the seller is genuine i'd doubt they'd mind - i'm thinking it's certainly wise to "see it for myself" rather than trust the seller to have not ripped off the sheet behind that lists the large number of expensive advisories that conveniently slipped their mind at the time of sale Wink)
Also regarding MOTs - do they usually give a good picture of the bike's condition because the list of items checked is very big (it's quite a comprehensive check, no?)
-- Ingah
Robert2014
PostPosted: 02:26 - 18 May 2010    Post subject: Reply with quote
it will show on the mot sheet if there was a adverizery noted at the time of the mot but for checkin online there isnt anything u can check mate
If you require a mechanic then I am your man. Bike collection and recovery service available. Don't let a monkey work on your bike, call the family run business on 07778 873 184 01505684994 https://www.rdbikes.co.uk [email protected]
Ingah
PostPosted: 02:52 - 18 May 2010    Post subject: Reply with quote
https://www.direct.gov.uk/en/motoring/owningavehicle/mot/dg_10020539 ?
It does actually say it will give you "full test information" - just that with no examples to see i was looking for confirmation it actually means "full" information from someone who's used it!
-- Ingah
Ichy
PostPosted: 06:39 - 18 May 2010    Post subject: Reply with quote
It does list all of the advisories but only the detail added my the MOT'er.
It will also let you look at the history of all the electronic MOTs, so roughly since 2005.
SlimRick
PostPosted: 06:50 - 18 May 2010    Post subject: Reply with quote
Here's what it shows on mine:
You asked for test history information for vehicle registration *****. You provided test number ****** to confirm that you had a legitimate interest in the vehicle. If you do not have a legitimate interest in the vehicle you must destroy the document. This information is correct at 18/05/2010.
Most Recent Vehicle Details and Test Summary applicable to this test number.
Registration mark:
Make/Model:
KAWASAKI / ZZR600
Colour:
PURPLE
VIN/Chassis No:
Approximate date of first use:
22/05/1993
Type of fuel:
Petrol
Date of test:
08/04/2010
Certificate issued (Pass)
Odometer reading:
61,547 Miles
Test number:
Test expiry date:
07/04/2011
Full Test History, starting with first recorded vehicle and test results
Registration mark:
Make/Model:
KAWASAKI / ZX600-E1
Colour:
PURPLE
VIN/Chassis No:
22/05/1993
Type of fuel:
Petrol
Date of test:
30/06/2007
Odometer reading:
50,026 Miles
Test number:
Test station name:
SPON GATE MOTORCYCLES
Test station number:
55285
Test station telephone number:
02476225111
Test class:
II
Test expiry date:
29/06/2008
Advisory Notice issued
Nearside Front Brake disc(s) slightly worn (3.2.A1l)
Offside Front Brake disc(s) slightly worn (3.2.A1l)
Rear Brake disc(s) slightly worn (3.2.A1l)
Drive chain slightly loose (6.2.1d)
Drive chain worn but not considered excessive (6.2.1e)
Date of test:
30/06/2008
Certificate issue refused (Fail)
Odometer reading:
50,822 Miles
Test number:
Test station name:
WINDSOR GARAGE
55851
02476 614837
Test class:
II
Reason(s) for refusal to issue Certificate
Front position lamp does not illuminate immediately when switched on (1.1.3a)
Front Brake pad(s) close to minimum limit (3.2A1f(ii))
Rear Brake pad(s) close to minimum limit (3.2.A1f(i))
Rear shock absorber bush Rear suspension bush has slight free play (2.4.A2a(i))
Very slight buckle on front wheel on rotation
Change of details
Make/Model:
KAWASAKI / ZZR600 recorded at time of test on 30/06/2008
Date of test:
30/06/2008
Odometer reading:
50,822 Miles
Test number:
Test station name:
WINDSOR GARAGE
55851
02476 614837
Test class:
II
Test expiry date:
29/06/2009
Date of test:
08/04/2010
Odometer reading:
61,547 Miles
Test number:
Test station name:
TRADE DIRECT
1ALR13
01142570111
Test class:
II
Test expiry date:
07/04/2011
No Advisory Notice issued
This completes the test history for the above vehicle as recorded on VOSA's MOT Computerisation Database
PostPosted: 08:26 - 18 May 2010    Post subject: Re: Seeing MOTs Online Reply with quote
No, not really. There's plenty it misses out and the majority of the checks you could pretty much do in five minutes looking over a bike (ie not get accurate figures regarding braking and headlight position.)
Also, some MOT testers are laxer than others, while others may pass one for a friend.
The last post was made 16 years, 118 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 53.07 Kb
