do new discs really need new pads?
dmh
PostPosted: 23:21 - 17 May 2010    Post subject: do new discs really need new pads? Reply with quote
i have finally brought myself to buy some new discs for my zx6, posted a while ago about the kagizume discs with mixed response-with a 1 tear warranty i am happy (if they are that bad they will go in a day or two and i will get something branded).
basically the pads i have on have loads of life left in them, and i can't really afford to for out another £50 new ones (hence why i bought eblag discs), do i need to change them?
only experience i have with brakes are on my downhill mtb, and for that a light sand would do the trick if at all anything.
thanks
dan
el_oso
PostPosted: 23:34 - 17 May 2010    Post subject: Reply with quote
anything happened to the pads like covered in oil or anything
Duke 390
Car: Jeep Wrangler 4.0L
dmh
PostPosted: 23:50 - 17 May 2010    Post subject: Reply with quote
i'm pretty sure they are clean. they have a mild squeak when they brush one area of the disc. other than that they are very good, s bike gets used regularly and is great under fast and harsh braking.
basically the current OEM discs are warped. which sounds worse than they are. low speed is horrible especially coming to a stop, high speed they are awesome, but an MOT failure
dan
Walloper
PostPosted: 07:57 - 18 May 2010    Post subject: Reply with quote
Well... Any manufacturer or dealer or good mechanic would recommend new pads on a new disc.
The pads 'fit' them self to the contours of the disc in service.
But... If you are happy that there is enough meat on the old pads then why not?
So long as they are in good condition and have sufficient material to get you to the next inspection/service interval then I would reuse the old ones.
But run them in as you would New Pads on an old disc.
defblade
PostPosted: 09:07 - 18 May 2010    Post subject: Reply with quote
I'd take it even easier than usual if using old pads. The high spots on the old pads won't match the high spots on the new discs - for the first few miles, you'll have very little pad to disc contact compared with normal, especially under light braking.
dmh
PostPosted: 20:11 - 18 May 2010    Post subject: Reply with quote
thanks guys
discs came today and look amasing! unfortunately, in order to maintain the 1 year warranty, i have to buy new pads anyway, so that's another £50 which i don't have!
booked in to be all fitted and set up on friday
dan
Paxovasa
PostPosted: 20:16 - 18 May 2010    Post subject: Reply with quote
dmh wrote:
thanks guys
dan
That's a con.
Having to get the dealer to fit the new discs Thumbs Down
Walloper
PostPosted: 23:01 - 18 May 2010    Post subject: Reply with quote
dmh wrote:
thanks guys
dan
I don't think they can hold you to that. There is a European court ruling on Manufacturer warranty blackmail from a few years back.
Something like..
So long as a recognised mechanic has fitted OEM parts warranty is still good.
Perhaps the warranty on HIS labour is not covered.
The last post was made 16 years, 122 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.96 - MySQL Queries: 13 - Page Size: 56.24 Kb
