hazard lights on my r6
ozzy r6
PostPosted: 13:37 - 18 May 2010    Post subject: hazard lights on my r6 Reply with quote
my r6 hazard lights have stopped working they flash once then don't do nothing but yet if you click the indicators right or left they work fine.
can anyone help me!
also does anyone one know if this is a mot fail as i have to get it mot next month
thans ozzy
PostPosted: 13:56 - 18 May 2010    Post subject: Re: hazard lights on my r6 Reply with quote
can anyone help me!
thans ozzy
Most bikes don't have hazard warning lights so I'd be very very surprised if it failed on that.
ripzay
PostPosted: 13:57 - 18 May 2010    Post subject: Reply with quote
I believe the stance is 'if it's there, it will be tested', stick some tape over the hazard lights switch, they can't test it and it will pass as hazard lights are not required on a motorcycle.
Current: 2005 KTM SuperDuke 990
Previous: 1996 Suzuki Bandit 600
Previous: 1994 Suzuki GSX-R 400
Wahlberg
PostPosted: 14:01 - 18 May 2010    Post subject: Reply with quote
My friend's a mechanic for honda, he told me if its standard at time of manufacture it gets tested and mods (eg. cigarette lighter/alarm) get overlooked
If you can't fix it with Gaffa tape, you havn't used enough Gaffa tape! Smile
ripzay
PostPosted: 14:23 - 18 May 2010    Post subject: Reply with quote
That's simply not true.
My bike had it's MOT at the start of this month, i removed the pollion pegs as one was snapped, these are standard, and were not tested.
The lighting on my bike is now 'always on' (i broke the switch in a drop), tape over the switch and it was a pass.
SOME modifications ARE tested in the MOT, for example; my jack-up dogbones were placed down as an advisory that the 'rear suspension has been modified', this means that while it has been modified, it is of a standard that passes the MOT and is placed on the MOT adivisories to cover the MOT test station.
It is perfectly legal to remove all the indicators from a motorcycle and cover up any associated switch gear and get a perfect pass through an MOT with no avisory notices...
Indicators are not a requirement on a motorcycle, but if they are present they will be tested and if faulty, will fail (bulb blown for instance).
The same applies for Hazard Warning Lights, if there is no switch then they cannot be tested; and as they are not required, there is no failure for them not being present. If present and faulty, they will fail.
Also note that an MOT tester is not allowed to remove anything from the bike during the test procedure, this will include the piece of tape you stick over the switch!
All of the above came from the mouth of my MOT tester less than 3 weeks ago, so because it's come from a person in a position of authority on the subject, I will take it as gospel.
truslack
PostPosted: 16:04 - 18 May 2010    Post subject: Reply with quote
I'm pretty sure you NEED pillion footpegs if you have a pillon seat.
Wrong. You can only remove indicators on a bike first used before 1986, or one that is designed for off road use, only carrying the rider. You can remove them off any bike if you mask/remove the headlight and tail light, but you will get an advisory stating that no lights were fitted at time of testing [edit] and I think mopeds aswell
You're right here, but they do have the right to refuse to test your bike if you refuse to remove covers that they need to remove to carry out tests. [edit] having checked my testers manual, they ARE allowed to remove covers that don't require tools
ozzy r6
PostPosted: 17:33 - 18 May 2010    Post subject: Reply with quote
thanks guys
does anyone know what could be wrong with it or where the hazard relay is located?
TUG
PostPosted: 17:36 - 18 May 2010    Post subject: Reply with quote
Could you tell me which R6 it is first?
Haz ER-5, innit!
ozzy r6
PostPosted: 17:41 - 18 May 2010    Post subject: Reply with quote
sorry its a 2003 model injection 5SL
TUG
PostPosted: 19:12 - 18 May 2010    Post subject: Reply with quote
Like most R6's the flasher relay is under your rider seat, Check the connections are clean in the flashers themselves and on the relay.
If you have after market flashers fitted then that might be half the problem.
Haz ER-5, innit!
silky666
Captain Rulebook
PostPosted: 19:18 - 18 May 2010    Post subject: Reply with quote
Its a long shot... but my R6 03 had a sticky flasher button today.
Pressed it in and they flashed once and then stopped.
I gave it a thump and behold, they are now all flashy again.
TUG
PostPosted: 19:30 - 18 May 2010    Post subject: Reply with quote
Couldn't you of just lubed it up when you got back? Laughing
Haz ER-5, innit!
silky666
Captain Rulebook
PostPosted: 19:56 - 18 May 2010    Post subject: Reply with quote
I get frustrated very quickly and tend to thump things.
It usualy works.
TUG
PostPosted: 19:58 - 18 May 2010    Post subject: Reply with quote
It usualy works.
I hope your OH doesn't frustrate you. Shocked
Haz ER-5, innit!
ozzy r6
PostPosted: 20:00 - 18 May 2010    Post subject: Reply with quote
Cheers guys i will have a look at it tomorrow i wouldn't have through that it would be the relay as the indicators still work and they would be on the same relay.
It has got after market indicators on they where on it when i got it
I will try give the switch a thump but i think i have done that already Laughing
TUG
PostPosted: 20:09 - 18 May 2010    Post subject: Reply with quote
Are they LED flashers? If they flash too quick then it might be wearing out the relay, you can buy aftermarket relays to stop this, but lets see what you have fitted first and if its the problem, could be a loose wire yet.
Haz ER-5, innit!
ozzy r6
PostPosted: 21:47 - 18 May 2010    Post subject: Reply with quote
i didn't fit them they was on the bike when i got it.
https://i653.photobucket.com/albums/uu256/redtoptigra_2009/Br7eJywWkKGrHqUH-EUEvGGKKUBL1ynJZ35.jpg
don't know if you can see them in this pic.
also the relay must be working if the indicators work its just the hazards don't. and they flash at the right speed.
TUG
PostPosted: 22:03 - 18 May 2010    Post subject: Reply with quote
This is burning my brain, if i had this bike on my bench infront of me heres what i'd do.
Check the fuses, all of them.
Take the switch gear apart and clean the contacts on the flasher controls (direction indi and hazards) and if the problem still persisted Start looking for a broken/corroded connection, still happening then check for a broken wire.
Haz ER-5, innit!
hondapartsman
PostPosted: 22:18 - 18 May 2010    Post subject: Reply with quote
For what is needed/ covered for the MOT read this
https://www.ukmot.com/bike/1-2.asp
For example a speedo does not have to work to pass the mot, my 250 one was not working and it passed. Even after all my years in the trade I did not realise that until last year.
In the end all comes back to the beginning
ozzy r6
cool i'll have the switch off it tomorrow and take it apart. its bugging me too as its just the hazards not working right. i'll let you know if i fix it cheers for advice.
ozzy r6
PostPosted: 22:26 - 18 May 2010    Post subject: Reply with quote
i'm a mot tester on cars and if they don't work on a car it is a fail but i know bike test's are different, i've looked at that manual and can't find anything to do with hazards but knowin my luck i'll send totest station and it will fail. Rolling Eyes
TUG
PostPosted: 19:45 - 19 May 2010    Post subject: Reply with quote
Got another vote for solenoid at work today, but i had a brain storm, check all the bulbs are the same wattage.
Haz ER-5, innit!
ozzy r6
PostPosted: 20:09 - 19 May 2010    Post subject: Reply with quote
i had a look at the wattage of the bulb today as didn't get time to look at switch,
each bulb is 21w now i'm thinking that the wattage of the bulbs are too high to run all four at the same time but will work two alright Confused
anyone agree Question
TUG
PostPosted: 20:17 - 19 May 2010    Post subject: Reply with quote
Just checked, the 21w bulbs are standard.
Haz ER-5, innit!
ozzy r6
PostPosted: 20:27 - 19 May 2010    Post subject: Reply with quote
i'm tryin to find out what they shoud be?
The last post was made 16 years, 109 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 127.18 Kb
