| ozzy r6 |
 ozzy r6 Renault 5 Driver
| MarJay |
 MarJay But it's British!
| ripzay |
 ripzay Nitrous Nuisance
| Wahlberg |
 Wahlberg Two Stroke Sniffer
 Posted: 14:01 - 18 May 2010 Post subject: |
My friend's a mechanic for honda, he told me if its standard at time of manufacture it gets tested and mods (eg. cigarette lighter/alarm) get overlooked ____________________ If you can't fix it with Gaffa tape, you havn't used enough Gaffa tape!  |
| ripzay |
 Posted: 14:23 - 18 May 2010 Post subject: |
| Wahlberg wrote: | My friend's a mechanic for honda, he told me if its standard at time of manufacture it gets tested and mods (eg. cigarette lighter/alarm) get overlooked |
That's simply not true.
My bike had it's MOT at the start of this month, i removed the pollion pegs as one was snapped, these are standard, and were not tested.
The lighting on my bike is now 'always on' (i broke the switch in a drop), tape over the switch and it was a pass.
SOME modifications ARE tested in the MOT, for example; my jack-up dogbones were placed down as an advisory that the 'rear suspension has been modified', this means that while it has been modified, it is of a standard that passes the MOT and is placed on the MOT adivisories to cover the MOT test station.
It is perfectly legal to remove all the indicators from a motorcycle and cover up any associated switch gear and get a perfect pass through an MOT with no avisory notices...
Indicators are not a requirement on a motorcycle, but if they are present they will be tested and if faulty, will fail (bulb blown for instance).
The same applies for Hazard Warning Lights, if there is no switch then they cannot be tested; and as they are not required, there is no failure for them not being present. If present and faulty, they will fail.
Also note that an MOT tester is not allowed to remove anything from the bike during the test procedure, this will include the piece of tape you stick over the switch!
All of the above came from the mouth of my MOT tester less than 3 weeks ago, so because it's come from a person in a position of authority on the subject, I will take it as gospel. ____________________ Current: 2005 KTM SuperDuke 990
Previous: 1996 Suzuki Bandit 600
Previous: 1994 Suzuki GSX-R 400 |
| truslack |
 truslack World Chat Champion
 Posted: 16:04 - 18 May 2010 Post subject: |
| ripzay wrote: |
I'm pretty sure you NEED pillion footpegs if you have a pillon seat.
Wrong. You can only remove indicators on a bike first used before 1986, or one that is designed for off road use, only carrying the rider. You can remove them off any bike if you mask/remove the headlight and tail light, but you will get an advisory stating that no lights were fitted at time of testing [edit] and I think mopeds aswell
You're right here, but they do have the right to refuse to test your bike if you refuse to remove covers that they need to remove to carry out tests. [edit] having checked my testers manual, they ARE allowed to remove covers that don't require tools
____________________ Current: Suzuki RG 125 Gamma, Honda H100, Triumph Tiger 800XC, Suzuki SV650 (minitwin) |
| ozzy r6 |
| TUG |
 TUG World Chat Champion
| ozzy r6 |
| TUG |
| silky666 |
 silky666 Captain Rulebook
| TUG |
 Posted: 19:30 - 18 May 2010 Post subject: |
Couldn't you of just lubed it up when you got back?  ____________________ Haz ER-5, innit! |
| silky666 |
| TUG |
| ozzy r6 |
 Posted: 20:00 - 18 May 2010 Post subject: |
Cheers guys i will have a look at it tomorrow i wouldn't have through that it would be the relay as the indicators still work and they would be on the same relay.
It has got after market indicators on they where on it when i got it
I will try give the switch a thump but i think i have done that already  |
| TUG |
| ozzy r6 |
| TUG |
| hondapartsman |
 hondapartsman Renault 5 Driver
 Posted: 22:18 - 18 May 2010 Post subject: |
For what is needed/ covered for the MOT read this
https://www.ukmot.com/bike/1-2.asp
For example a speedo does not have to work to pass the mot, my 250 one was not working and it passed. Even after all my years in the trade I did not realise that until last year. ____________________ In the end all comes back to the beginning |
| ozzy r6 |
| ozzy r6 |
 Posted: 22:26 - 18 May 2010 Post subject: |
i'm a mot tester on cars and if they don't work on a car it is a fail but i know bike test's are different, i've looked at that manual and can't find anything to do with hazards but knowin my luck i'll send totest station and it will fail.  |
| TUG |
| ozzy r6 |
 Posted: 20:09 - 19 May 2010 Post subject: |
i had a look at the wattage of the bulb today as didn't get time to look at switch,
each bulb is 21w now i'm thinking that the wattage of the bulbs are too high to run all four at the same time but will work two alright
anyone agree  |
| TUG |
| ozzy r6 |
The last post was made 16 years, 108 days ago. Instead of replying here, would creating a new thread be more useful? |
