Wobbling SPeedo needle (& cables snapping)
Smooth
PostPosted: 12:21 - 21 May 2010    Post subject: Wobbling SPeedo needle (& cables snapping) Reply with quote
My bike was laid-up for a few months and when riding it again I noticed that the speedo needle was wandering.
The cable snapped so I replaced it. The needle wobbled a bit up to about 60mph, so I took out the cable and lubed it.
The needle wobbled a bit less and only up to about 35mph -I rode it like that for a few weeks.
The cable then snapped.
I bought another cable and greased the drive gear at both the wheel end and at the speedo end.
I used a power drill to spin the broken cable in the speedo unit and found that the needle moved smoothly between 0 and 60 mph. I lubed it with WD40 fitted the new cable.
The needle now wobbles a little at low speed and I noticed that it sometimes does it at much higher speeds on my private driveway. It seems to do it intermittently.
Have I just bought poor quality, dragging speedo cables?
Can the speedo cable housing vibrating in the wind (at high speed) cause drag?
Any other ideas?
TDM850
serlant
PostPosted: 13:20 - 21 May 2010    Post subject: Reply with quote
sounds like it could be the teeth on the speedo drive?
Ichy
PostPosted: 13:33 - 21 May 2010    Post subject: Reply with quote
Has the routing of the cable changed in any way?
Smooth
PostPosted: 13:35 - 21 May 2010    Post subject: Reply with quote
The drive teeth appeared to be intact.
Not significantly. It is a fairly direct between the wheel and the clocks with no sharp bends.
TDM850
serlant
PostPosted: 14:17 - 21 May 2010    Post subject: Reply with quote
Where abouts is the cable snapping?
Smooth
PostPosted: 15:04 - 21 May 2010    Post subject: Reply with quote
The first time it was near the bottom, the second time close to the top.
TDM850
The last post was made 16 years, 1 day ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.58 - MySQL Queries: 13 - Page Size: 47.14 Kb
