How constant should my idle be ?
hornetmike
PostPosted: 22:20 - 21 May 2010    Post subject: How constant should my idle be ? Reply with quote
Had to adjust my idle speed on 96 CBR because it seems to be fluctuating, how steady should it be ?
And what should I service to fix it, plugs haven't long been changed.
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
Noxious89123
PostPosted: 22:22 - 21 May 2010    Post subject: Reply with quote
When were the carbs last balanced?
cb1rocket
PostPosted: 22:23 - 21 May 2010    Post subject: Reply with quote
it should be very steady, if jumpy then your carbs need to be sync
hornetmike
PostPosted: 22:24 - 21 May 2010    Post subject: Reply with quote
Cheers , I'll book it in to get balanced.
Its done 18k will valve clearence efect it ?
Ichy
PostPosted: 08:28 - 22 May 2010    Post subject: Reply with quote
Tickover on the CBR can change by up to 100 rpm. Lots of things can affect it, such as pin holes in the exhaust, but a carb balance and valve check are good places to start. Just remember that the valves need to be done first.
If the bike hasn't been serviced for a bit then it worth changing the air filter and checking any fuel filter that's fitted as well.
Did the problem only start once the plugs were changed or was it already there?
The last post was made 16 years, 160 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 43.34 Kb
