Honda CG125 Oil
astroscope
PostPosted: 12:18 - 22 May 2010    Post subject: Honda CG125 Oil Reply with quote
Hi Guys,
I'm thinking of doing an oil change soon. The bike is a 4 stroke engine and I've always used 4 stroke engine oil.
Tesco are selling motorbike engine oil for a 2 stroke engine for £5.50 a litre. Castrol brand. Will this be ok in my engine?
thanks guys
2010 Honda FES S Wing 125
Frost
PostPosted: 12:19 - 22 May 2010    Post subject: Reply with quote
No, not at all.
astroscope
PostPosted: 12:22 - 22 May 2010    Post subject: Reply with quote
oh ok...
thanks
Alexio
PostPosted: 13:41 - 22 May 2010    Post subject: Reply with quote
It will completely destroy your engine.
2 stroke oil is designed to be mixed with fuel and lubricate the piston directly. It is therefore also kind of burnt as fuel.
In a 4 stroke engine the oil never mixes with the fuel, it is not designed to be burned off inside of the engine and will be an incredibly poor lubricant in the sump of your engine in comparison. Your piston might seize, your bore will be scored, your piston and rings ruined, your valves, bearings, cams etc, etc, all ruined.
And anyway, Morrisons value oil, 1L (which is how much you need) costs about £1 or just over, so do the right thing Thumbs Up
astroscope
PostPosted: 18:17 - 22 May 2010    Post subject: Reply with quote
Thanks for the advice
astroscope
PostPosted: 18:20 - 22 May 2010    Post subject: Reply with quote
£1for oil at morrisons? That's cheap. Infact so cheap I'm scared of putting it in! Shocked
Alexio
PostPosted: 18:56 - 22 May 2010    Post subject: Reply with quote
It's technically not the recommended oil because it's not synthetic stuff (I think?) but my CG has done thousands of miles without any complaints.
temeluchus
PostPosted: 19:47 - 22 May 2010    Post subject: Reply with quote
CG doesnt require synthetic.
Morrissons usually carry Halvoline Premium, 5 litres for under a tenner. This is a reasonable 15/40 engine oil, fine for your CG.
The Artist
PostPosted: 20:06 - 22 May 2010    Post subject: Reply with quote
Synthetic is for tuned bikes running at temperatures and speeds your CG wouldn't dream of reaching.
Any old 10/40w will do.
Alexio
PostPosted: 20:25 - 22 May 2010    Post subject: Reply with quote
Ah yeah, that would be it. I use 10/40w and I've been told that 15/40 is better although I doubt it makes much difference on a bike like a CG.
Keir
PostPosted: 00:18 - 23 May 2010    Post subject: Reply with quote
yet you would have considered 2 stoke oil? Laughing
Current : '08 Yamaha FZ1s
Alexio
PostPosted: 00:34 - 23 May 2010    Post subject: Reply with quote
No, it's all about price see. If we had of told him to go out and find stuff labeled "dot 4 brake fluid" he probably would have spent a fortune to buy enough to fill up his engine Laughing
hondapartsman
PostPosted: 07:58 - 23 May 2010    Post subject: Reply with quote
What you have to bear in mind is that the CG engine was designed for use in third world countries so was designed to run on just about anything slippery enough. In places like India if you change your oil by the roadside you'll have someone after your used oil before it finishes dripping out of the bike. There is a lot of crap talked about oil, in our workshop we use 10/40 semi synthetic on all but very few bikes. I have used the same in my bikes for years and never a problem, my old 250 runs on the oil I've drained out of my 600 and my wifes car, but then as it's a bit leaky it has a self changing oil system anyway so until I get that sorted it seems a waste putting new in. Still going after a few years even of that though. Bike semi, at least the brand we use, seems to be getting cheaper in relation to the same stuff for a car though. There was a time I could save £2 a litre buying car stuff, closer to £1.00 now.
In the end all comes back to the beginning
PostPosted: 10:29 - 23 May 2010    Post subject: Reply with quote
the only time i ever buy semi synthetic/fully is for the car...thats because it asks for it.
The bikes usually get the bog standard havoline 10w40 or opie oils when a deals on for semi stuff
The last post was made 16 years, 124 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 81.58 Kb
