superdream 400 clutch
wargamesuk
PostPosted: 15:22 - 22 May 2010    Post subject: superdream 400 clutch Reply with quote
Hi im put a new clutch in my 400n
but ctwhat does line up the tangs of the friction plates
so that they are level with each other
but when i took the clutch off the tangs was not level so what do i do
- this
MaybeGuy
PostPosted: 15:25 - 22 May 2010    Post subject: Reply with quote
stagger them
tbh it doesnt really matter that much
wargamesuk
PostPosted: 16:45 - 22 May 2010    Post subject: thanks Reply with quote
thanks will give it ago
i dont need any parts got lots of them for my 400n
wargamesuk
PostPosted: 18:53 - 22 May 2010    Post subject: Reply with quote
ok did that and it slips now
MaybeGuy
PostPosted: 19:00 - 22 May 2010    Post subject: Reply with quote
that wont be caused by the plates arrangement.
springs, clutch adjustment or plate wear.
hondapartsman
PostPosted: 08:03 - 23 May 2010    Post subject: Reply with quote
I agree, try spacing the springs with washers. I had clutch slip on my 250 single, checked the springs and they were just under the proper spring length, I had a spare clutch with better springs, put those in, fine again. Under normal use plates last ages in my opinion, nearly 60,000 on mine now, I was later advised putting washers under the bolt heads would have done the same though.
In the end all comes back to the beginning
PostPosted: 08:31 - 23 May 2010    Post subject: Reply with quote
Putting in an extra steel plate does the same thing, just put two together.
wargamesuk
PostPosted: 12:21 - 23 May 2010    Post subject: Reply with quote
ok i think i fix it
just put new clutch cable on it and ok work for now
wargamesuk
PostPosted: 10:42 - 13 Jun 2010    Post subject: clutch Reply with quote
ok put new clutch plates an spring in bike
and now the gear will not return so can not change down gear
Question
PostPosted: 11:29 - 13 Jun 2010    Post subject: Re: clutch Reply with quote
Question
You have the gear lever centering spring out of place. It's behind the clutch basket on the lower left as I recall. The spring is on the end of the long rod that the gear lever acts on and has two legs that should be either side of a pin (working from memory). Take the cover off and take a photo of the workings.
wargamesuk
PostPosted: 12:54 - 13 Jun 2010    Post subject: clutch Reply with quote
ok here some pic and yes it ring
https://i45.tinypic.com/2yp0qad.jpg
https://i50.tinypic.com/125lvnp.jpg
https://i47.tinypic.com/2im9smd.jpg[/img]
The last post was made 15 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 68.57 Kb
