| Leviathan91 |
 Leviathan91 Scooby Slapper
| ZRX61 |
 ZRX61 Victor Meldrew
| Leviathan91 |
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| Paddy Blake |
 Paddy Blake World Chat Champion
| Leviathan91 |
 Posted: 23:46 - 25 May 2010 Post subject: |
| Quote: |
As above:
Your cooling system is a pressurised system meaning it wont boil off (your coolant becomes superheated) and it basically never goes down unless there is a leak.
Check your hoses before jumping to conclusions, a blowing head gasket will have a range of symptoms - i.e. white gunky oil from a water emulsion, contaminated coolant (can get a cheap test done at a garage to confirm), leaking coolant, overheating, a fat cloud of steam from your exhaust and your overheating but working after cooling for 10 mins symptom - etc etc.
If you are lucky, it might just be that your coolant system has a big leak and it has all boiled off.
Good luck  |
Hmm, when my 2 stroke oil was changed before there was white in it? I was rather puzzled as it should be pure pink? Either way I have a leak though right? I mean it must be going somewhere? Although deffiantley not on the floor.
Sorry for the noobish comments I am quite cluess. My exhaust would chuck out a LOT of fumes to begin with, but that might just be normal.
So it's leaking none the less? Surley it's the gasket? How else can it leak? |
| Paddy Blake |
| DrDonnyBrago |
| Kaph |
 Kaph Nitrous Nuisance
 Posted: 23:52 - 25 May 2010 Post subject: |
| Leviathan91 wrote: | | Quote: |
As above:
Good luck  |
White in the 2-stroke means water's in there I think, not good. |
| Leviathan91 |
| Paddy Blake |
| Leviathan91 |
| Walloper |
 Walloper Super Spammer
| Kaph |
| Phoenix |
 Phoenix Twisted Firestarter
| Paddy Blake |
| Leviathan91 |
| Kaph |
| Leviathan91 |
 Posted: 00:08 - 26 May 2010 Post subject: |
Guys I'm going to bed I'm fucking wrecked. Had to push it home for a couple of miles was not happy.
I appreciate all your help so far, will check back tomorrow.
Just to recap on details of my problem:
:arrow:Coolant has dropped half...
Bike will run for about 10mins at most before dieing
Bike was running well for about half hour
Once rested, bike needs bump (depending on rest duration)
Once it dies it has the symptoms of when it's been flooded. I.E you wait for a while, and it gets back to life again. Gear changes are fine, and it accelerates/revs perfectly fine. |
| Leviathan91 |
| Walloper |
| ZRX61 |
| Freaky_1 |
 Freaky_1 Nova Slayer
 Posted: 05:24 - 26 May 2010 Post subject: |
Easy way to spot a blown head gasket on a water cooled two cycle is to pop the plug, grab a bright light and look down at the top of the piston. If it seems to have been steam cleaned, then it likely has.
This isn't the end all answer, but it's a quick and easy answer in most cases.
Pop your plug and see if there's carbon on the top of the piston. If it's very very clean, then you can just about bet that the head gasket is blown.
However, there is NO reason to not check hoses, cap, w/p, radiator flues, and such (as mentioned by several above), while you're there.
BTW, this will work for four cycle engines as well, but it's much more accurate on an oil burning engine. |
| Walloper |
 Posted: 13:35 - 26 May 2010 Post subject: |
| Freaky_1 wrote: | Easy way to spot a blown head gasket on a water cooled two cycle is to pop the plug, grab a bright light and look down at the top of the piston. If it seems to have been steam cleaned, then it likely has.
This is a good tip.
What about the pistons of a Jet engine??  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| Kickstart |
 Kickstart The Oracle
The last post was made 16 years, 106 days ago. Instead of replying here, would creating a new thread be more useful? |
