How does coolant work? Need help.
Leviathan91 This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
ZRX61
Victor Meldrew
PostPosted: 23:24 - 25 May 2010    Post subject: Reply with quote
If it isn't leaking, it lasts right up to the point you drain it...which reminds me, haven't checked mine in about 3 years...
DrDonnyBrago
PostPosted: 23:37 - 25 May 2010    Post subject: Reply with quote
Leviathan91 wrote:
Sweet well I know thew problem then, cheers. Thumbs Up
As above:
Your cooling system is a pressurised system meaning it wont boil off (your coolant becomes superheated) and it basically never goes down unless there is a leak.
Check your hoses before jumping to conclusions, a blowing head gasket will have a range of symptoms - i.e. white gunky oil from a water emulsion, contaminated coolant (can get a cheap test done at a garage to confirm), leaking coolant, overheating, a fat cloud of steam from your exhaust and your overheating but working after cooling for 10 mins symptom - etc etc.
If you are lucky, it might just be that your coolant system has a big leak and it has all boiled off.
Good luck Thumbs Up .
Paddy Blake
PostPosted: 23:43 - 25 May 2010    Post subject: Reply with quote
Coolant will evaporate so needs to be checked monthly at least depending how much you ride the bike.
Paddy Blake
PostPosted: 23:48 - 25 May 2010    Post subject: Reply with quote
Could be water pump seal and not head gasket.
DrDonnyBrago
PostPosted: 23:51 - 25 May 2010    Post subject: Reply with quote
Leviathan91 wrote:
Hmm, when my 2 stroke oil was changed before there was white in it? I was rather puzzled as it should be pure pink? Either way I have a leak though right? I mean it must be going somewhere? Although deffiantley not on the floor.
Sorry for the noobish comments I am quite cluess. My exhaust would chuck out a LOT of fumes to begin with, but that might just be normal.
So it's leaking none the less? Surley it's the gasket? How else can it leak?
2 stroke oil just gets burnt off and shouldnt be affected by a dodgy head gasket, it gets used up and doesnt require changing in the traditional sense... what bike is this BTW?
Kaph
PostPosted: 23:52 - 25 May 2010    Post subject: Reply with quote
Leviathan91 wrote:
As above:
Good luck Thumbs Up
White in the 2-stroke means water's in there I think, not good.
Paddy Blake
PostPosted: 23:55 - 25 May 2010    Post subject: Reply with quote
I think he means gearbox oil was white but maybe not.
Water pump seal.
Walloper
PostPosted: 23:58 - 25 May 2010    Post subject: Reply with quote
It can't evaporate from a sealed system unless it is vented due to overheating or system leaks.
The check is really only to ensure there is no leakage or other reson for coolant loss.
Kaph
PostPosted: 23:59 - 25 May 2010    Post subject: Reply with quote
I'm realllyyy confused. So the coolant level has dropped? It should be a completely closed system, some will occasionally go into an overflow tank if the RS has one, but it'll be taken back when the pressure drops.
As for changing the 2 stroke, its a total loss system. All the 2 stroke you put in there gets mixed in and burnt.
If the coolant level has dropped by half(!) you have a leak.
Phoenix
Twisted Firestarter
Is it overheating? If it's not then you no doubt have a leak or your radiator cap has failed and isn't holding pressure. If it is overheating then your thermostat could be stuck closed or partially closed and it's boiling off and coming out of the overflow.
Paddy Blake
PostPosted: 00:02 - 26 May 2010    Post subject: Reply with quote
It is not a sealed system.
Kaph
PostPosted: 00:04 - 26 May 2010    Post subject: Reply with quote
Leviathan91 wrote:
I have no idea if it's over heating... I dont think so becuase I have a temperature sensor. However that could be inaccurate.. It will fuck at 50-90c.
I think the coolant is deffiantley being used, just being flooded with it.
How difficult would the gasket be to replace? IF, that's the problem.
Head gasket really not that hard. But if it is that causing coolant to go into the cylinder, you'd have a host of issues. If the head gaskets gone, the compression'll be low aswell.
Walloper
PostPosted: 00:31 - 26 May 2010    Post subject: Reply with quote
Would you care to elabourate?
It's a sealed system if there is a cap.
The cap will prevent transfer of gas/fluid between the cooling system and the atmosphere.
Provided there is no overpressurization in the system.
There are no Non-sealed systems fitted to modern motorcycles. The coolant would fall out when cornering.
ZRX61
Victor Meldrew
PostPosted: 04:16 - 26 May 2010    Post subject: Reply with quote
Unless it's a sealed, pressurized system... Wink
Freaky_1
PostPosted: 05:24 - 26 May 2010    Post subject: Reply with quote
Easy way to spot a blown head gasket on a water cooled two cycle is to pop the plug, grab a bright light and look down at the top of the piston. If it seems to have been steam cleaned, then it likely has.
This isn't the end all answer, but it's a quick and easy answer in most cases.
Pop your plug and see if there's carbon on the top of the piston. If it's very very clean, then you can just about bet that the head gasket is blown.
However, there is NO reason to not check hoses, cap, w/p, radiator flues, and such (as mentioned by several above), while you're there.
BTW, this will work for four cycle engines as well, but it's much more accurate on an oil burning engine.
Walloper
PostPosted: 13:35 - 26 May 2010    Post subject: Reply with quote
This is a good tip. Thumbs Up
What about the pistons of a Jet engine?? Razz
PostPosted: 13:58 - 26 May 2010    Post subject: Reply with quote
Leviathan91 wrote:
RS125, 2001.
But if it's leaking it must be because of the head gasket? What other component would make it leak?
Could be the head gasket, water pump seal, base gasket or even the crankcase halves not correctly sealed together (on the RS engine this can allow water directly from the water pump into the crankcases).
Water pump seal would allow the water into the gearbox, so your gearbox oil would be milky. None of the others would likely allow the oil and water to mix.
If the 2 stroke oil tank is full of pink fluid (like strawberry milkshake) then that is probably a separate issue.
The last post was made 16 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 133.89 Kb
