| rich400 |
 rich400 L Plate Warrior
| Pete. |
 Pete. Super Spammer
 Posted: 15:10 - 23 May 2010 Post subject: |
I know it sounds obvious rich but have you tried just removing a spark plug and putting it in a cap, resting it on the engine and seeing if there's a spark when it's cranking? ____________________ a.k.a 'Geri'
| rich400 |
| Pete. |
 Pete. Super Spammer
 Posted: 22:36 - 23 May 2010 Post subject: |
So you have a spark? That points to a fuelling problem, which is a common thing on the 400 bandit. ____________________ a.k.a 'Geri'
| alun111 |
 alun111 World Chat Champion
| rich400 |
| Pete. |
 Pete. Super Spammer
 Posted: 17:29 - 24 May 2010 Post subject: |
Rich, just to confirm, do you actually SEE a spark when you crank the engine with a loose plug in a cap? ____________________ a.k.a 'Geri'
| rich400 |
| Pete. |
 Pete. Super Spammer
 Posted: 18:56 - 24 May 2010 Post subject: |
Ok lemme decipher the wiring diagram and I'll get back to you with some advice. ____________________ a.k.a 'Geri'
| Pete. |
 Pete. Super Spammer
 Posted: 19:31 - 24 May 2010 Post subject: |
Right.
The sidestand relay sends power to the kill switch. This in turn passes power to the starter button, and the ignitor.
If it is turning, then there's nothing wrong with the Ignition switch, sidestand switch, sidestand relay or kill switch.
That leaves wiring to the ignitor or coils, or faulty ignitor, or faulty signal generator.
To check the ignitor wiring pull the plug from the ignitor and put a meter on the Orange and White wire. You should have 12V there with the ignition and kill switch on.
If you have no voltage there but the engine will crank when you hit the starter button you have a wiring fault.
If you have voltage there you should check the connectors aren't green and rotted. Check also the terminals in the ignitor. Best bet is to take photos of both and post them here.
To check the coil wiring put a volt meter on each of the orange wires feeding the coils. Should be 12v there directly from the ignition switch.
If the terminals look ok you should test the signal generator. The connector you can find by removing the seat and left air cleaner cover. Unplug the connector and measure the resistance of the sensor (brown wire and black with blue tracer wire). The serviceable range is 80-120 ohms.
Do all this and see where you get mate  ____________________ a.k.a 'Geri'
| Pete. |
 Pete. Super Spammer
 Posted: 19:36 - 24 May 2010 Post subject: |
Ignition wiring: ____________________ a.k.a 'Geri'
| cb1rocket |
 cb1rocket World Chat Champion
| alun111 |
| rich400 |
 Posted: 18:28 - 25 May 2010 Post subject: wiring bandit 400 wont start |
ive found that a wire that goes into the fuse box dosent look very gd and the bit where the connectors goes into the fuse box looks abit expanded(on the fuse box) i did have a problem on the day the bike stopped that the fuse that that particular wire goes into the plastic on the fuse melted so im hopin this wire could be the problem im sorry for sounding so stupid i love bikes and yes this is my 1st as u can tell  ____________________ RICHY |
| alun111 |
| rich400 |
| alun111 |
| alun111 |
The last post was made 16 years, 135 days ago. Instead of replying here, would creating a new thread be more useful? |
