Stuck again
rac3r
PostPosted: 17:18 - 26 May 2010    Post subject: Stuck again Reply with quote
This time it's not a rounded bolt but a stuck one Doh!
I need to loosen the bolt for the banjo for the brake and clutch lines but the thing won't budge! Any ideas how to loosen it?
Chequered Flag
Paxovasa
PostPosted: 17:24 - 26 May 2010    Post subject: Reply with quote
Plenty penetrating fluid Thumbs Up
Jayy
Mr. Ponzi
Use a claw hammer and obliterate it.
rac3r
PostPosted: 17:26 - 26 May 2010    Post subject: Reply with quote
WD40?
Chequered Flag
Blackwolf
Burgerfist
PostPosted: 17:29 - 26 May 2010    Post subject: Reply with quote
No, real penetrating fluid. Freeze and realase. Tried heating it?
PostPosted: 17:30 - 26 May 2010    Post subject: Reply with quote
Brake fluid is very very flammable, so no. Don't heat it.
rac3r
Not tried heating it, failing that I'll have to go get some stuff
EDIT: Don't heat Laughing
Chequered Flag
Frost
PostPosted: 17:43 - 26 May 2010    Post subject: Reply with quote
I assume you have tried the standard things:
Shouting at it
Hitting the head of it with something
Questioning its lineage
Squirting half a can of WD-40 at it
Hitting it harder
Otherwise, make sure your using a socket with a snug fit, not a half inch instead of a 13mm. Try and get a socket that grips the flats rather than the corners like this:
https://www.turnermotorsport.com/image/tools/tools_6pt_socket_46mm_TMI9910M46_lg.jpg
Tap the socket wrench handle with a hammer sharply and it will loosen.
rac3r
PostPosted: 17:59 - 26 May 2010    Post subject: Reply with quote
Still nothing. The whole lever and master cylinder moved Shocked
Chequered Flag
PostPosted: 18:09 - 26 May 2010    Post subject: Reply with quote
attach a hex socket, longest ratchet you can find....then add a piece of old exhaust/scaffold bar.
The scaffold bar was my weapon of choice with a GS i picked up...it has removed every single rusty stuck bolt inc. exhaust header bolts!
we used 2 people really..one holding the scaffold onto the ratchet while the other did a very sharp quick movement to free it.
Blackwolf
Burgerfist
PostPosted: 18:15 - 26 May 2010    Post subject: Reply with quote
Hmm cheers for that Mayjay, forgot about that. Laughing
Scaffold bar is an awsom tool!
Theres still freeze and release? WD40 will not be as effective as proper penetrating fluid. (Durex will not help)...
Charlie
PostPosted: 18:17 - 26 May 2010    Post subject: Reply with quote
Tried tightening it a little bit and then undoing it? Can sometimes get it going
Rob W
PostPosted: 18:21 - 26 May 2010    Post subject: Reply with quote
Try putting a socket on it and give it a couple of firm taps, sometimes that'll be enough to free the threads and get it moving.
Rob W
PostPosted: 18:33 - 26 May 2010    Post subject: Reply with quote
Well, by firm I mean give a fcuking good whack. If it shocks it enough it should free the threads, as soon as it 'cracks' your laughing.
rac3r
PostPosted: 19:21 - 26 May 2010    Post subject: Reply with quote
I'll have to wait for reinforcements because I need someone else to hold it
Chequered Flag
Frost
PostPosted: 21:21 - 26 May 2010    Post subject: Reply with quote
Put it on the floor and put your foot on it and undo it?
The last post was made 16 years, 109 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 86.52 Kb
