| Stefan RS50 Wood |
 Stefan RS50 Wood Derestricted Danger
 Posted: 17:05 - 26 May 2010 Post subject: RS50 Think its slippigg |
New to this 1st Post
My rs50 , 53reg is slipping like when i drive it, i can be in gear 6 and its red lining at like 20mph, but if i stay below 7revs its fine
how hard is it to fit new clutch plates because i think its that
Thx |
| Crafty |
 Crafty Derestricted Danger
 Posted: 18:07 - 26 May 2010 Post subject: |
Very easy if you know what your doing, & fairly easy even if you don't, but can wield a spanner.
If in doubt get a pro to do the work.
You will need a clutch holding tool, a new sets of plates, a new set of springs & a clutch cover gasket as well. Fresh engine oil because its wet multiplate which means the oil in the gearbox is used to cool & lube the clutch.
First of all, remove fairing lowers & bellypan to reveal engine.
Remove sump plug (14mm socket fits I think?) & drain gearbox oil, clean sump plug of debris & refit. Remove clutch crankcase cover to expose clutch basket. Carefully unbolt the retaining bolts USING CLUTCH HOLDING TOOL to stop it from rotating, remove springs remove all plates. Fit new plates in same formation as old ones removed. Fit NEW SPRINGS as well clean engine casing & clutch cover mating surfaces, fit a new gasket, refit cover fill with fresh 10/40 oil adjust clutch & thats it basically.
https://www.ultimateparts.net/info/aprilia-bikes-rs/aprilia-bikes-rs.php?bike=354
https://www.ultimateparts.net/aprilia/a.php?n=AP8201527-Clutch-lock-ENGINE-TOOL-KIT-Aprilia-Special-Tools-D-Minarelli-AM6-Aprilia-Tools&i=338347 ____________________ To FINNISH 1ST, 1ST you gotta FINNISH.
Fastest is the 1ST to CROSS the FINNISH LINE.
2ND, IS the 1ST of all the LOSERS. |
| N cee thirty |
 N cee thirty Banned
| Faraz |
 Faraz Nearly there...
| Stefan RS50 Wood |
 Posted: 22:09 - 26 May 2010 Post subject: Re: RS50 Think its slippigg |
| Stefan RS50 Wood wrote: | New to this 1st Post
Thx |
Thanks im not too bad with bikes soo ile have ago, i can get the plates off adrenaline pedstop for 20quid with the springs and whats this Gasket i will need ? |
| ms51ves3 |
 ms51ves3 Super Spammer
| Stefan RS50 Wood |
| Faraz |
There is a gap of 3 years, 179 days between these two posts... |
| Scott richards |
 Scott richards L Plate Warrior
| nathan k |
 nathan k Spanner Monkey
The last post was made 12 years, 211 days ago. Instead of replying here, would creating a new thread be more useful? |
