| MrJames |
 MrJames Two Stroke Sniffer
 Posted: 00:44 - 27 May 2010 Post subject: Suzuki GN125 Running Problems.... |
Hope someone here can help having a few problems with my suzuki GN125 for a while after starting this happens while trying to ride and when the bike is just idling if you open the throttle it revs to about 2k rpm then bogs down and trys to stall and will but if you ease off a bit it'll struggle then eventually start reving more normally.
I've replaced the carb with a copy which I've pulled apart to make sure theres nothing wrong with it and it's all fine I've checked the fuel flow from the petcock the plug is white which indicates it's running lean which is more than likely part of my problem but the carb only has an idle mixture screw.
Any ideas? Had enough of looking like an idiot with no clutch control lol  |
| paddlesat16 |
 paddlesat16 Crazy Courier
| Watdafukhappe... |
 Watdafukhappe... Two Stroke Sniffer
 Posted: 14:17 - 27 May 2010 Post subject: |
| Watdafukhappe... |
 Posted: 14:36 - 27 May 2010 Post subject: |
Sorry I've just re-read your post and it says you've already checked the plug. As stinkwheel has said, check for an air leak.
Has it always done this? (i.e. since you bought it?) Was the plug fine before? If it was always like this then you should buy a pack of jets and up-jet if no air leaks are found as running lean is not good for your engine.  |
| MrJames |
The last post was made 16 years, 46 days ago. Instead of replying here, would creating a new thread be more useful? |
