Suzuki GN125 Running Problems....
MrJames
PostPosted: 00:44 - 27 May 2010    Post subject: Suzuki GN125 Running Problems.... Reply with quote
Hope someone here can help having a few problems with my suzuki GN125 for a while after starting this happens while trying to ride and when the bike is just idling if you open the throttle it revs to about 2k rpm then bogs down and trys to stall and will but if you ease off a bit it'll struggle then eventually start reving more normally.
I've replaced the carb with a copy which I've pulled apart to make sure theres nothing wrong with it and it's all fine I've checked the fuel flow from the petcock the plug is white which indicates it's running lean which is more than likely part of my problem but the carb only has an idle mixture screw.
Any ideas? Had enough of looking like an idiot with no clutch control lol Embarassed
paddlesat16
PostPosted: 13:54 - 27 May 2010    Post subject: Reply with quote
first thing whip the plug out and look at the colour, this will tell you how the carb is running - rich-lean etc.
plug should be a nice biscuit brown colour
if black = Rich
no colour i.e white=super lean
there is a plug guidline on a sticky in the workshop somewhere.
Regards
I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T.
Watdafukhappe... This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
PostPosted: 14:21 - 27 May 2010    Post subject: Reply with quote
My first suspect would be an air leak somewhere round the carb.
MrJames
PostPosted: 15:12 - 27 May 2010    Post subject: Reply with quote
When I first got the bike it was reving on it's own when I stripped the carb down I found holes in the diaphram so not sure what it was like before so replaced the carb with a replica I've replaced the plug and reseated the carb and checked for air leaks and can't find anything wound trying to raise the needle height work?
The last post was made 16 years, 103 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 48.03 Kb
