Attaching bicycle computer sensor
Smooth
PostPosted: 07:45 - 27 May 2010    Post subject: Attaching bicycle computer sensor Reply with quote
The previous owner had fitted a bike computer.
The sensor was mounted to the caliper and the magnet to the rim with some sort of black double-sided tape.
I replaced the calipers and am now looking to re-fit the sensor.
Am I correct in assuming that the car badge/number plate double-sided tape would be the correct stuff to use?
TDM850
PostPosted: 08:02 - 27 May 2010    Post subject: Reply with quote
Double sided tape will hold it in place, or you can just use one of these. Smile
https://lisaligia.files.wordpress.com/2009/08/cable_tie.jpg
Smooth
PostPosted: 08:29 - 27 May 2010    Post subject: Reply with quote
Cable-ties aren't that helpful in sticking plastic to an alloy brake caliper.
The magnet is already in place so I'll re-fit the sensor in the original position.
TDM850
DrDonnyBrago
PostPosted: 09:27 - 27 May 2010    Post subject: Reply with quote
Give it a go, maybe a cable tie to catch it if the adhesive fails from heat though Thumbs Up .
skatefreak
PostPosted: 11:03 - 27 May 2010    Post subject: Reply with quote
Whats the bike comp on there for?
Does it give any advantages over the stock clocks etc?
Cover for malfunctioning clocks?
Just curious how useful these can be Smile
Best regards
-Jvr
Watdafukhappe... This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Smooth
PostPosted: 15:22 - 27 May 2010    Post subject: Reply with quote
I'm using it as back-up for the speedo.
The Sigma I've got seemed accurate when I used it before. ie. consistently reading a couple of mph below the analogue speedo, even at motorway speeds.
TDM850
Smooth
PostPosted: 15:54 - 27 May 2010    Post subject: Reply with quote
[quote="Subfocus"]
Smooth wrote:
In that case it's actually more accurate then your analogue speedo, as they over read. Confused Laughing
I know, hence me saying that it seemed accurate
Rolling Eyes
Adjusting the circumference value up would result in the computer speedo over-reading slightly, for a margin of error.
TDM850
The last post was made 16 years, 107 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.6 - MySQL Queries: 13 - Page Size: 60.72 Kb
