| Handsome |
 Handsome World Chat Champion
| el_oso |
 el_oso World Chat Champion
| Handsome |
| mistergixer |
 mistergixer World Chat Champion
 Posted: 11:27 - 29 May 2010 Post subject: |
Does your motherboard have onboard graphics, or is it an external card only?
If it has, it's possible your bios has defaulted to the onboard - if so, try the other connector, or try tapping whatever key that enters the bios on boot up - usually delete or F10.
Also try completely removing and reseating the external card.
If all this fails, it's most likely that your graphics card has failed.
I had this exact same problem a little while ago with my Dad's PC, it was the graphics card which had failed. I always keep a box of obsolete/junk pc components that i've removed from other PCs when i've upgraded them.(loads of old pci and agp graphics cards etc) So i popped round with another card and just replaced it. He only uses his PC for very basic stuff (web-browsing and word processing), so he doesn't notice the difference. ____________________ Space Monkey #7
Mistergixer's videos on YouTube |
| Handsome |
 Posted: 15:30 - 30 May 2010 Post subject: |
I honestly don't know, I'll dig the box out later for the specs and I'll post them up as computer internal aren't my thing...
Thank you for the help so far...  ____________________ Previous Bikes...Honda NSR 125 RR...Kawasaki Zephyr 550...Suzuki SV 1000 S...Yamaha FZ8...Current Bike...Suzuki GSX-R 750... |
| Handsome |
| mistergixer |
 Posted: 22:59 - 01 Jun 2010 Post subject: |
The Scaleo P is the Fujitsu model name for the 'whole' PC.
The GA-81848 is the main board, manufactured by Gigabyte.
From what i can glean, that series of mainboard did not feature onboard graphics, instead it uses an AGP graphics card.
(AGP is very basically the kind of 'slot' that the card fits into.)
I would recommend getting a cheapie from eBay or similar, this link will show you some of them. Failing that, a local PC spares shop might have a few old AGP cards in stock that they'll let you have for cheap.
Might be worthwhile taking your video card out and comparing the style of connector to the ones in the eBay adverts before you part with your money. ____________________ Space Monkey #7
| Handsome |
| Flip |
 Flip Super Spammer
 Posted: 18:31 - 02 Jun 2010 Post subject: |
Your monitor will plug into the back of your graphics card.
Type "fitting graphics cards" (or similar) in to youtube, that'll give you an idea of what they look like. |
| mistergixer |
 Posted: 23:55 - 02 Jun 2010 Post subject: |
^^ What he said.
Here is a picture of a similar Gigabyte mainboard:
https://www.gigabyte.com/fileupload/product/2/1787/420.jpg
In this picture, the lime green 'slot' is the AGP slot where your graphics card fits in.
The other 5 large slots are PCI slots, note how they are a different size and shape from the AGP slot.
Note also that the AGP slot has a little white lever on it, this locks onto a little tab on the graphics card.
Here is a picture of an AGP card:
https://www.ertyu.org/steven_nikkel/images/agpuniv.jpg
Note the little 'L' shaped green tab at the bottom of the card, this is what helps to lock the card in place.
Usually, the AGP card will be held in place by that locking tab and a single screw which secures it to the PC case.
To remove the card: find the screw and remove it, push the locking lever down on the mainboard, the card should now come out. It may require a bit of a wiggle (technical term) to free it from the slot. If it doesn't come out too easily, start looking for something else which is holding it in place.
Here's a pic of a different AGP card:
https://static.howstuffworks.com/gif/agp-card.jpg
What we're looking at in this pic is the front of the card where the connectors are - you should recognise the blue 'D' connector as being the same as where you plug your monitor cable in.
To the left of the blue monitor connector (known as a VGA socket), the other side of the 2 yellow connectors can you see where the metal bends at 90 degrees? This is where you will find the screw which holds the graphics card to the PC chassis.
(Note, you might not have the yellow connectors, but your card will pretty much definitely have that bend and screw hole).
If you're buying from the t'interwebs, post a link of the replacement card you're buying and we'll be able to tell you if it's suitable.
| Handsome |
 Posted: 17:19 - 03 Jun 2010 Post subject: |
Cheers peeps, I'll whip the cover off and have a look...  ____________________ Previous Bikes...Honda NSR 125 RR...Kawasaki Zephyr 550...Suzuki SV 1000 S...Yamaha FZ8...Current Bike...Suzuki GSX-R 750... |
| neil. |
 neil. World Chat Champion
 Posted: 19:17 - 03 Jun 2010 Post subject: |
Before spending money, there are a few things you can try. I would reset the CMOS - should be a little jumper point on the motherboard that you short for 10 seconds or so whilst the PC is off, then unshort it again (use a key or something conductive to bridge the 2 pins). Also try simple stuff like taking out the RAM and any cards and blowing out the slots in case a bit of dust has got in and is preventing proper contact being made. Also, something may have been dislodged enough to stop it booting and reseating all the cards will help with this.  ____________________ CBT February 2008 | A2 June 2008 | Yamaha YBR125 (written off) | Honda CBF125 (current) |
| Handsome |
The last post was made 16 years, 100 days ago. Instead of replying here, would creating a new thread be more useful? |
