| ba |
 ba Borekit Bruiser
| P.addy |
 P.addy Red Rocket
| ba |
 ba Borekit Bruiser
| 27cows |
 27cows World Chat Champion
| P.addy |
 P.addy Red Rocket
| ba |
 ba Borekit Bruiser
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 00:37 - 30 May 2010 Post subject: |
before you change the pump,
i would be pulling the head off and cleaning the dome, piston, and ring grooves of carbon,
i know 27cows is against doing regular piston de-coking but its something i do regularly on my smokies,
i would also check the choke, and re-clean your carb, making sure all jets are clear ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| 27cows |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 09:33 - 30 May 2010 Post subject: |
or ignore the above and set the mixture screw correctly (NOT the idle screw with a spring behind it). screw it in all the way and back it out 1 and a half turns (i think this is right. been ages since ive set up an rxs carb).
easiest place to start. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| UnspeedySam |
 UnspeedySam World Chat Champion
| 27cows |
 Posted: 19:09 - 30 May 2010 Post subject: |
Unless the mixture screw has been tinkered with, that won't be the problem. I haven't touched mine in 50,000 miles or more - there's no need.
I encountered the choke problem on a mate's RXS years ago. The spring had broken and all cocked to one side. The choke appeared to work normally but wasn't closing properly. Only way to be sure it's OK is to try one that you know works...but unscrewing it and a visual inspection should be enough.
The amount a stroker smokes can depend on the weather conditions. Mine smokes like buggery when it's anything but warm. Then again the motor has done an immense mileage The original motor hardly smoked at all, and used to do about 1000 miles to a litre of 2T But it lasted well and ran lovely. ____________________ The RXS100: vehicle of choice for Chuck Norris |
| UnspeedySam |
| 27cows |
| UnspeedySam |
| 27cows |
 Posted: 20:53 - 30 May 2010 Post subject: |
More likely a poor contact. I have a dodgy indicator warning light that doesn't work for a week...and then comes back again
An impact driver is probably the most important 'special' tool you can own, with the possible exception of a flywheel puller. ____________________ The RXS100: vehicle of choice for Chuck Norris |
| ba |
 ba Borekit Bruiser
 Posted: 23:39 - 31 May 2010 Post subject: |
| 27cows |
 Posted: 08:01 - 01 Jun 2010 Post subject: |
I wish I was closer. Looks extremely tidy. Don't see many that low mileage these days. ____________________ The RXS100: vehicle of choice for Chuck Norris |
| ba |
 ba Borekit Bruiser
| 27cows |
| MaybeGuy |
 Posted: 08:47 - 04 Jun 2010 Post subject: |
225? Mine was 70 ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| ba |
 ba Borekit Bruiser
The last post was made 16 years, 135 days ago. Instead of replying here, would creating a new thread be more useful? |
